Steveie d
Sync 3 Map Update updates BUT doesn't update!
I've upgraded my 2015 Focus sync 2 to sync 3 having bought a second hand apim and screen. All working great. The Apim was on sync 2.1 so I updated the sync to sync 3.0 using the donor car VIN. I then adjusted the file with the donor cars VIN and sent it to ford website. It then correctly offered a map update as It was on the bulk standard F6.1. It downloaded the update and I unzipped it to the USB and applied it ton the car. After 40 minutes it said update complete and remove USB. I then locked the car for 5 minutes and then checked the maps. STILL F6.1! I again tried the USB stick but after a few mins said update complete! So it says update complete but doesn't show on the about screen! Any ideas?
Try leaving it locked for longer. 15-30 mins.
If still not after that force restart sync.
I did this a few days ago so it's been locked for over 12hours! I've also master reset. How do you force a sync restart? I'm baffled by this! All other updating worked perfectly! Also no upload file created on USB for the ford site
You hold the physical eject and skip forwards. Or hold both skip forward physical buttons on the HU and steering wheel if you don’t have an eject button.
That enters the diagnostic pages rather than restart
Power and skip, restarted but still says F6.1. It's adamant that's what's installed but I've updated it with the latest download from ford sync site and if I try again it says update complete, but still sit on the original
Are you sure you are using the correct maps for that version of sync? What does it say in the auto install file. And what version of sync are you running?
Top pic, sync and nav version, next pic ford sync website showing update, next root file of usb, next contents of sync my ride file. ONLY thing I can think of is does the update somewhere store the intended VIN number, ie donor car, as my sync from the donor car now shows my VIN, hence when I updated sync, I had to edit the file To send back to ford with the donor cars VIN in order for it to offer the map update. (The sync made the file with my cars VIN as that's what its connected to now, and my car is too old for free updates!)
The build number seems to be missing from sync.
Where it says the word build should be a version number.
I've got map version f8
That's the point! This is AFTER I applied the downloaded update from the ford site and the car said it was successful! It still shows as the old version! Anyone know why? What's gone wrong?
There is no map file in those files.
14G422 is Voice
14G423 is Gracenotes
Whats the content of the autoinstall file? Open it with notepad.
14G422 is Voice
I wonder if you’ll have to wait for the next part.
There is no map update. But the files are the F8 nav voice.
Maybe when the server registers the voice update it will give you the map file.
14G421 will be the map.
Thanks. How do I make the system know I've applied what I have? There is no file to download to the site!
The sync website has a link to the tool to make the xml somewhere on the update page.
I've uploaded the file having found how to make 1, it now says maps up to date! Of course I'm only on 6.1!
5 minutes ago, alexp999 said:
It can take a little time for the server to offer the next file.
Superb! Thanks alex999 for your help!!!! I was very confused but at least you know the map files! I'd just assumed what I'd downloaded was the map file! Remember reading can take a week now!
Maybe I've got f8 because mines a bit newer 67 plate but registerd in 2018
Today the map update was offered, so superb! F9 installed. Problem solved. Thanks for the help, needs a sync update to 3.0 then it says a map update, but its not updating the map itself, once uploaded to ford servers it seems it's 48 hours, then the actual map is offered!
  Only 75 emoji are allowed.
