  1. Tap the 3-dot menu (â‹®) in the top-right corner of the browser.
Focus 1.6 tdci no start after Change filter
Hello members 🙂 I need your help I have a Ford Focus mk2 1.6 tdci 80kw 2006 A general was made on the engine. Dpf is removed and switched off as well as the Egr valve blocked and switched off. Remap stage 1 (150 hp) done The exhaust is without a pot last, a good sound The car worked perfectly until I replaced the fuel filter (iron) Now it won't work, vergla but without success. I turn it on to the start spray, and it works until I turn it off. Then it won't work and start the spray again: / Occasionally it jerks while driving and sometimes it won't over 3000 rpm Help please 🙂
You will need to disconnect the fuel return line and pump out the air bubbles.
But it is not clear to me how the car works after starting, when it goes out then it will not start
It can still start with air bubbles but will cause the symptoms you are talking about.
Thy I Will try
On 03. 07. 2020. at 17:56, F0CUE said:
Još uvijek može započeti zračnim mjehurićima, ali izazvat će simptome o kojima govorite.
New filter is sct germany
OS that good?
