yunii Posted August 12, 2020 Share Posted August 12, 2020 as title says but the front seem to work. I've checked owners manual says fuse 12720 amp but it say electric windows not front or rear ?? but fronts work , I'm guessing it has a separate fuse for rears.anyone know which one ?saves me going through every single one. yunii Sent from my SM-G960F using Tapatalk Quote Link to comment Share on other sites More sharing options...
leicsguyuk Posted August 12, 2020 Share Posted August 12, 2020 I presume you've checked the child safety switch that demobilise's the rear passager windows? Quote Link to comment Share on other sites More sharing options...
yunii Posted August 12, 2020 Author Share Posted August 12, 2020 are you on about child lock catch that you turn with key on side of door ?if yes it was working after I turned it on ?its both rear windows switch Sent from my SM-G960F using Tapatalk Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted August 12, 2020 Share Posted August 12, 2020 He means the window cut off switch, it's the long thin one below the rear switches on the driver's door. Quote Link to comment Share on other sites More sharing options...
yunii Posted August 12, 2020 Author Share Posted August 12, 2020 He means the window cut off switch, it's the long thin one below the rear switches on the driver's door.yes it was that I must have pressed it at some point. lolyunii Sent from my SM-G960F using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
