aydamstoidy Posted August 20, 2020 Share Posted August 20, 2020 Anyone had this? Opened my driver side door and water dripped onto the driveway. Found that the water had come from the door seal and had came out of the small hole at the bottom. It's not leaked into the car so the seals are doing their job but not sure if this is supposed to happen? Coincidentally the same side window is pretty slow when closing and I'm hoping these aren't related at all. Quote Link to comment Share on other sites More sharing options...
Mavroz Posted August 21, 2020 Share Posted August 21, 2020 Not had that problem with seals or Windows. Quote Link to comment Share on other sites More sharing options...
aydamstoidy Posted August 21, 2020 Author Share Posted August 21, 2020 Hm, the car is under warranty till next February so I may have to get it looked at. Seems strange to me that the motor could be at fault in the windows but I doubt it on a 67 plate. Hoping the water dripping out the door seal and the windows going up slowly aren't related in any way though I can see how they would be Quote Link to comment Share on other sites More sharing options...
aydamstoidy Posted August 21, 2020 Author Share Posted August 21, 2020 Hopefully this makes more sense with pictures. I'm wondering if it's just a build up of water sitting on the skirts that causes it. The seals are pinned in correctly as you can see but you can see where it leaks from. As for the window the drivers side closes marginally slower than the passenger side so might try some silicone spray Quote Link to comment Share on other sites More sharing options...
Tom44 Posted August 21, 2020 Share Posted August 21, 2020 Weirdly enough i noticed this the other day, came on to ask and saw this thread. This is the inner door seal. 1st image is about the middle of the door, the 2nd is at the back, it is a 3 door model and appears to be perishing as well, anyone else had this issue, 18 plate so wouldn't expect to see this so soon? 2nd image has warn all the way through, haven't noticed any water ingress, though it being the inner seal shouldn't do. Haven't noticed anything like that with the outer door seal though. Quote Link to comment Share on other sites More sharing options...
aydamstoidy Posted August 21, 2020 Author Share Posted August 21, 2020 27 minutes ago, Tom44 said: Weirdly enough i noticed this the other day, came on to ask and saw this thread. This is the inner door seal. 1st image is about the middle of the door, the 2nd is at the back, it is a 3 door model and appears to be perishing as well, anyone else had this issue, 18 plate so wouldn't expect to see this so soon? 2nd image has warn all the way through, haven't noticed any water ingress, though it being the inner seal shouldn't do. Haven't noticed anything like that with the outer door seal though. Strange to be happening on an 18 plate. My seals aren't like that, no visible damage it seems like the water filling on the skirt just goes into the seal somehow? Although I think that's probably not supposed to happen 😝 I'm not sure how yours could have worn like that Quote Link to comment Share on other sites More sharing options...
Tom44 Posted August 21, 2020 Share Posted August 21, 2020 4 minutes ago, aydamstoidy said: Strange to be happening on an 18 plate. My seals aren't like that, no visible damage it seems like the water filling on the skirt just goes into the seal somehow? Although I think that's probably not supposed to happen 😝 I'm not sure how yours could have worn like that Nor am i, seems strange, almost like they are separating down the seam, would be covered under the warranty do you reckon? Quote Link to comment Share on other sites More sharing options...
aydamstoidy Posted August 21, 2020 Author Share Posted August 21, 2020 1 hour ago, Tom44 said: Nor am i, seems strange, almost like they are separating down the seam, would be covered under the warranty do you reckon? I don't see why not. I will wait to see if anyone else has had a similar issue to mine (water dripping from seals when I open the door) to see if it's worth going through under the warranty. Surely they can't put it down as "wear and tear" on a 2 year old car 2 Quote Link to comment Share on other sites More sharing options...
