FordMondeomk4 Posted September 3, 2020 Share Posted September 3, 2020 Hello My mondeo got the clutch pedal stuck, does anyone know why?best regards Quote Link to comment Share on other sites More sharing options...
FatHead1979 Posted September 12, 2020 Share Posted September 12, 2020 On 9/3/2020 at 4:57 PM, FordMondeomk4 said: Hello My mondeo got the clutch pedal stuck, does anyone know why? best regards A bit more information would help. Is it stuck up or down? Can you pull it up with your foot? If so, does it stay up? Any difference in behaviour between when the engine if off or running? Quote Link to comment Share on other sites More sharing options...
MasterTechTip Posted September 12, 2020 Share Posted September 12, 2020 If it's stuck down you've either got a hydraulic leak in the pipe or at the slave cylinder. Or there's the possibility of the system sucking in air at the master cylinder. 1 Quote Link to comment Share on other sites More sharing options...
Locksnapper Posted January 15, 2023 Share Posted January 15, 2023 On 9/12/2020 at 6:55 PM, FatHead1979 said: A bit more information would help. Is it stuck up or down? Can you pull it up with your foot? If so, does it stay up? Any difference in behaviour between when the engine if off or running? Hi FatHead i have the same problem. To answer your questions: stuck down i can pull it up and it stays up. seems to work (at the moment) while engine is running/driving. I have a judder in my clutch, so I am assuming my clutch is on the way out, but not sure if this is linked or coincidence Quote Link to comment Share on other sites More sharing options...
unofix Posted January 15, 2023 Share Posted January 15, 2023 On 9/12/2020 at 7:12 PM, MasterTechTip said: If it's stuck down you've either got a hydraulic leak in the pipe or at the slave cylinder. Or there's the possibility of the system sucking in air at the master cylinder. As above. Quote Link to comment Share on other sites More sharing options...
Locksnapper Posted January 15, 2023 Share Posted January 15, 2023 Thanks @unofix. So after I posted this I found a spring hanging down (picture attached to illustrate), which I’ve reattached. But there is defo still an issue as the clutch isn’t as smooth (certainly when the engine isn’t running) as before. The slave cylinder, is that inside the gear box? And if so, does that come as part of a 3 piece clutch kit (as I’m wondering what the difference is to a 2 piece clutch kit!?) 1 Quote Link to comment Share on other sites More sharing options...
unofix Posted January 15, 2023 Share Posted January 15, 2023 13 minutes ago, Locksnapper said: The slave cylinder, is that inside the gear box? No, but it is a problem to get at. It is on most Fords these days located inside the clutch/gearbox Bell Housing. I'm not up much on clutch system you have maybe @iantt would know the answer Quote Link to comment Share on other sites More sharing options...
iantt Posted January 15, 2023 Share Posted January 15, 2023 3 hours ago, unofix said: No, but it is a problem to get at. It is on most Fords these days located inside the clutch/gearbox Bell Housing. I'm not up much on clutch system you have maybe @iantt would know the answer Pretty much all the fords use the slave cyl inside the bell housing. Gearbox out to do. 3 piece clutch required if it's already juddering. The spring that broke is just a clutch pedal return spring that doesn't do much in reality. 1 1 Quote Link to comment Share on other sites More sharing options...
Locksnapper Posted January 16, 2023 Share Posted January 16, 2023 thanks @iantt, I’ve taken into the garage for a replacement. The car has done 175k miles, is it worth replacing flywheel too? Quote Link to comment Share on other sites More sharing options...
iantt Posted January 16, 2023 Share Posted January 16, 2023 37 minutes ago, Locksnapper said: thanks @iantt, I’ve taken into the garage for a replacement. The car has done 175k miles, is it worth replacing flywheel too? At that sort of miles definitely. 1 Quote Link to comment Share on other sites More sharing options...
