Alex.S Posted September 14, 2020 Share Posted September 14, 2020 For some reason today I can’t adjust audio volume while using CarPlay It’s stuck on prompt volume. Is there a way to change between different volumes ? I’d been adjusting prompt volume whilst getting a prompt , never figured out how else to do it.. Quote Link to comment Share on other sites More sharing options...
FezMan Posted September 14, 2020 Share Posted September 14, 2020 I have a similar thread going just a few down from this about car play freezing, in there someone mentioned holding the power button and skip track to force restart the sync system Give this a try and see if that solves it, the ol' case of turn it off and on... Edit, just realised you actually replied to that thread so you've probably already tried this!🤨 1 Quote Link to comment Share on other sites More sharing options...
Alex.S Posted September 14, 2020 Author Share Posted September 14, 2020 1 minute ago, FezMan said: I have a similar thread going just a few down from this about car play freezing, in there someone mentioned holding the power button and skip track to force restart the sync system Give this a try and see if that solves it, the ol' case of turn it off and on... I tried the soft reset , no joy. Unplugging the phone.... it all works fine on sync. the ol’ off and on definitely works in most scenarios! Not in this case , though I’ll go back to it later ..probably fixed itself. Quote Link to comment Share on other sites More sharing options...
Alex.S Posted September 14, 2020 Author Share Posted September 14, 2020 11 minutes ago, FezMan said: just realised you actually replied to that thread so you've probably already tried this Yeah, I’ve used the reset a few times in the year I’ve had the car. Have you tried the power / rewind ? I saw it mentioned, diagnostic menu ? Quote Link to comment Share on other sites More sharing options...
FezMan Posted September 14, 2020 Share Posted September 14, 2020 58 minutes ago, Alex.S said: Have you tried the power / rewind ? I saw it mentioned, diagnostic menu ? Its a menu where you can run speaker tests etc, and can also change the theme. I've never played with it fully (get paranoid about somehow breaking it) so have never saved any settings (if its even possible) Anyway this video shows what I mean Quote Link to comment Share on other sites More sharing options...
Alex.S Posted September 14, 2020 Author Share Posted September 14, 2020 18 minutes ago, FezMan said: get paranoid about somehow breaking it) so have never saved any settings (if its even possible) It’s probably the way to sort my volume issue but I too get para ! Quote Link to comment Share on other sites More sharing options...
simps100 Posted September 14, 2020 Share Posted September 14, 2020 2 hours ago, Alex.S said: For some reason today I can’t adjust audio volume while using CarPlay It’s stuck on prompt volume. Is there a way to change between different volumes ? I’d been adjusting prompt volume whilst getting a prompt , never figured out how else to do it.. I had this and I found it was caused by Waze on my iPhone - even when it wasn’t open. Deleting Waze fixed it for me which is a shame but this was too annoying to live with! 1 Quote Link to comment Share on other sites More sharing options...
Alex.S Posted September 14, 2020 Author Share Posted September 14, 2020 19 minutes ago, simps100 said: Deleting Waze fixed it for me which is a shame but this was too annoying to live with! Thanks, audio volume has decided to work again! If it plays up I’ll delete Waze , I don’t use it anyway. How did you figure out it was Waze ? Process of elimination? Quote Link to comment Share on other sites More sharing options...
colinmcg71 Posted September 14, 2020 Share Posted September 14, 2020 I saw this article a while back which highlighted the waze problem. 1 Quote Link to comment Share on other sites More sharing options...
simps100 Posted September 14, 2020 Share Posted September 14, 2020 Saw some posts about it in the US on a Mustang forum which made me give it a go - it was really frustrating issue nearly always come back! 1 Quote Link to comment Share on other sites More sharing options...
Alex.S Posted September 15, 2020 Author Share Posted September 15, 2020 Deleting Waze has resolved the audio volume issue. Ive noticed plugging the phone in, using Carplay for a short while then back to sync it’s lost an hour on the clock.. Quote Link to comment Share on other sites More sharing options...
FezMan Posted September 15, 2020 Share Posted September 15, 2020 39 minutes ago, Alex.S said: Ive noticed plugging the phone in, using Carplay for a short while then back to sync it’s lost an hour on the clock.. This was more than likely caused when you did a force restart or master reset if you tried one, took me a day or two to notice the last time I tried this.. 1 Quote Link to comment Share on other sites More sharing options...
