SP23 Posted September 16, 2020 Share Posted September 16, 2020 Hi, I have a Mk7 fiesta 1.4tdci which needs injector seals changing. (Been looked at by mechanic) . Contacted Ford and no reply with part cost or even part number, so question to all is: Anyone have a part number for this part? Where to buy this from? Anyone care to share a link please? How many seals are there? Many thanks!! 1 Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted September 17, 2020 Share Posted September 17, 2020 Hi, The problem with buying these items at Ford is they only supply them in large quantities so you're better off buying from eBay. Each injector has a copper washer (seal), a plastic guide bush and a rubber o-ring. It's recommended to change all 3 when injectors are removed. There are hundreds advertised on eBay so it's difficult to know which to choose. I'd suggest most are the same quality but it's probably worth double checking that they're correct with the seller once you have chosen a set. This is just the first set that I came across on eBay - https://www.ebay.co.uk/itm/FUEL-INJECTOR-SEAL-WASHER-ORING-SET-FOR-FIESTA-1-4-TDCi-2001-ON-DIESEL/253412841075 2 Quote Link to comment Share on other sites More sharing options...
SP23 Posted September 17, 2020 Author Share Posted September 17, 2020 Hi, Thank you for the reply. Yeah, the amount of different types on eBay has got me confused! Thank you for the link, i have emailed seller to check if it is correct part. 1 Quote Link to comment Share on other sites More sharing options...
tomshepp Posted September 22, 2020 Share Posted September 22, 2020 Honda ones are slightly thicker and softer. They are widely recommended as giving a more reliable seal than most others. Quote Link to comment Share on other sites More sharing options...
Martin ing Posted September 20, 2022 Share Posted September 20, 2022 Did you sort this out as I need to do the same Quote Link to comment Share on other sites More sharing options...
BP2411 Posted September 25, 2022 Share Posted September 25, 2022 Not the OP, but I've done this job a couple of times and it's a major PITA, are you looking to do it yourself or take it to a garage? 1 Quote Link to comment Share on other sites More sharing options...
isetta Posted September 25, 2022 Share Posted September 25, 2022 When they started leaking on my old 1.6tdci I just did the bolts/ nuts up a bit tighter and that cured it. Don’t overdo it. If you snap it / strip thread you will have a major problem 1 Quote Link to comment Share on other sites More sharing options...
BP2411 Posted September 26, 2022 Share Posted September 26, 2022 18 hours ago, isetta said: When they started leaking on my old 1.6tdci I just did the bolts/ nuts up a bit tighter and that cured it. Don’t overdo it. If you snap it / strip thread you will have a major problem I snapped a bolt doing this once and believe it or not it was actually surprisingly easy to remove, I didn't even attempt to use an easy out because I've never once seen one work in real life, instead I drilled 2 holes next to each other and removed it with a flat head screwdriver. 1 Quote Link to comment Share on other sites More sharing options...
isetta Posted September 26, 2022 Share Posted September 26, 2022 I’ve never had any joy with a easy out either, they snap and then are resistant to drilling. 1 Quote Link to comment Share on other sites More sharing options...
eswaby271 Posted February 14 Share Posted February 14 On 9/25/2022 at 9:54 AM, BP2411 said: Not the OP, but I've done this job a couple of times and it's a major PITA, are you looking to do it yourself or take it to a garage? Do the copper seals come out separate or do they come out with the injectors and what do you use to clean the ports and injectors? Thank you Quote Link to comment Share on other sites More sharing options...
BP2411 Posted February 22 Share Posted February 22 On 2/14/2024 at 9:18 PM, eswaby271 said: Do the copper seals come out separate or do they come out with the injectors and what do you use to clean the ports and injectors? Thank you If you're lucky they come out with the injectors if not you need to get a removal tool. To clean the injector seats, you need an injector seat cleaner tool. Quote Link to comment Share on other sites More sharing options...
