rooby_roo Posted October 7, 2020 Share Posted October 7, 2020 Hi all, i have a 2010 kuga 2.0l diesel with 134k on the clock, ive had the dpf light coming on for a while now, its coding p002, i have changed the sensor, checked the rubber pipes under the car going onto the dpf, but they are fine and dont look that old tbh, the dpf is not blocked, the car loses no power when the eml light comes on, it still drives as it should, but ive noticed on hard exceleration there seems to be a whisle sound, sort of like an air leak, but checked all the hoses etc. could someone point me in the right direction as to why the code keeps popping up. thanks in advance Quote Link to comment Share on other sites More sharing options...
pragmatix Posted October 8, 2020 Share Posted October 8, 2020 Hose leaks are very hard to find, a tip,is to use soupy water on the hoses, leaks show as bubbles. Quote Link to comment Share on other sites More sharing options...
rooby_roo Posted October 8, 2020 Author Share Posted October 8, 2020 sorry the code should of read P2002, Also when i coded it again today it also came up with P1335, egr position sensor minimum stop performance. Quote Link to comment Share on other sites More sharing options...
alx8oy Posted October 9, 2020 Share Posted October 9, 2020 On 10/7/2020 at 11:55 PM, rooby_roo said: Hi all, i have a 2010 kuga 2.0l diesel with 134k on the clock, ive had the dpf light coming on for a while now, its coding p002, i have changed the sensor, checked the rubber pipes under the car going onto the dpf, but they are fine and dont look that old tbh, the dpf is not blocked, the car loses no power when the eml light comes on, it still drives as it should, but ive noticed on hard exceleration there seems to be a whisle sound, sort of like an air leak, but checked all the hoses etc. could someone point me in the right direction as to why the code keeps popping up. thanks in advance If you can hear an air leak i reckon the dpf is blocked solid. Had a customer do that before the air leak noise was exhaust gases trying to escape and gaps it could where the dpf is blocked. Any diesel car with 134k on the clock will have a blocked dpf by now as most poodle round town. Egr fault will be your orignal fault which accelerates dpf blockage. hope this helps. Quote Link to comment Share on other sites More sharing options...
iantt Posted October 10, 2020 Share Posted October 10, 2020 I would check if you have a fuel vapouriser on your dpf. Known to block up and stop regens. Sure your Kuga will have one. This is an example of what to look for on your car ( but only an example off a transit for visualisation. ) https://www.ebay.co.uk/itm/202272643105 Quote Link to comment Share on other sites More sharing options...
