FiestaForever
Uprated stage 2-3 clutch
I am looking into tuning parts for ford fiesta mk5 1.25 16v 75bhp. I found a small supercharger that could be fitted to the car but wanted some help with finding a clutch suitable that will fit.
I understand that the clutch has to be the right size for the fly wheel to be compatible. The stock size is 190mm and 17 spline teeth. Unfortunately I cannot seem to find any performance uprated clutches for the fiesta model I own.
my question is would an uprated clutch with 190mm diameter, 17 spline teeth from another car make, e.g a fiat uno turbo, fit into a ford fiesta? What determines the compatibility? Would the bolt holes be the same? Can I install a clutch with a larger  diameter from a larger engine fiesta?
Any help would be appreciated, I am sure we have some experts here at the club.
Ok so I found some information on some clutch ideas running from stage 1 - 3. All are not too pricey, fairly reasonable, and are made to vehicle specifications.
There are also some other performance products that would compliment the clutch kits.
https://www.larkspeed.com/shopper/i/DT8CP1280/Ford-Fiesta-Mk6-1-2i-16v-DriveTorque-Stage-3-Clutch-Kit
  Only 75 emoji are allowed.
