michaelburrows Posted October 12, 2020 Share Posted October 12, 2020 iv noticed one of the rear door seals on my car has started coming away from the door. it looks like its stuck on with some type of glue. i want to refix it before it gets worse and hangs off. has anyone any idea which glue/sealant would be best to use. Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted October 12, 2020 Share Posted October 12, 2020 There is a proper fix for this as it's a common Mk3 fault. @iantt knows the right stuff to use... 1 Quote Link to comment Share on other sites More sharing options...
iantt Posted October 12, 2020 Share Posted October 12, 2020 There is a bonding agent that ford use but a tube of tigerseal does the job. https://www.ebay.co.uk/itm/333504716586 2 Quote Link to comment Share on other sites More sharing options...
TitXlover Posted October 12, 2020 Share Posted October 12, 2020 Stuck mine with super glue. OK so far.Sent from my SM-T720 using Tapatalk Quote Link to comment Share on other sites More sharing options...
BigLen Posted October 12, 2020 Share Posted October 12, 2020 1 Quote Link to comment Share on other sites More sharing options...
DaSingh Posted October 13, 2020 Share Posted October 13, 2020 I used Loctite 406 Quote Link to comment Share on other sites More sharing options...
michaelburrows Posted October 13, 2020 Author Share Posted October 13, 2020 thanks guys. seems any adhesive then. Quote Link to comment Share on other sites More sharing options...
BigLen Posted October 13, 2020 Share Posted October 13, 2020 3 minutes ago, michaelburrows said: thanks guys. seems any adhesive then. I'd suggest leaving the door open for a while to dry; perhaps obvious but nobody said; Tiger seal is what I would choose; because it remains flexible when fully cured. Much like chewing gum has a small bit of flex left in it. Quote Link to comment Share on other sites More sharing options...
Maddave Posted October 13, 2020 Share Posted October 13, 2020 Have the same problem on my Mk4, booked into main dealer on Friday to have it replaced under warranty. 1 Quote Link to comment Share on other sites More sharing options...
DaveT70 Posted October 13, 2020 Share Posted October 13, 2020 7 minutes ago, Maddave said: Have the same problem on my Mk4, booked into main dealer on Friday to have it replaced under warranty. Yep, coming off on RH front door of my MK4 too. TVM have probably costed out the spirit wipe process prior to fit. 1 Quote Link to comment Share on other sites More sharing options...
michaelburrows Posted October 13, 2020 Author Share Posted October 13, 2020 pain in the bum. ivhad lots of different cars. when doors have frozen shut in winter i have literally pulled em open with so much force id thought the handle would come off. but never had a ***** door seal so much as budge. 1 Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted October 13, 2020 Share Posted October 13, 2020 Ever had a 306? I snapped the driver's door handle off 3 of those damn cars. Only one was in ice lol!! It's not like I'm particularly strong either...thankfully tech moved on to the tougher pull handles instead of the old flat lifters lol. 1 Quote Link to comment Share on other sites More sharing options...
mjt Posted October 14, 2020 Share Posted October 14, 2020 14 hours ago, TomsFocus said: Ever had a 306? I snapped the driver's door handle off 3 of those damn cars That's the French and their bio-degradeable plastic. I'd never buy another French car. 1 Quote Link to comment Share on other sites More sharing options...
pcaouolte Posted October 14, 2020 Share Posted October 14, 2020 I broke the door handle on a Mondeo trying to get it open when the door was frozen shut. Since then, at the start of each winter I give the rubber door seals a coat of Gummi Pflege. Never had a door frozen shut since. Quote Link to comment Share on other sites More sharing options...
