DaSingh Posted October 13, 2020 Share Posted October 13, 2020 So slowly slowly my list of mods have been increasing! Trying to keep it all factory and not go over the top. Now that my sync3 upgrade is done, I was thinking of doing the instrument cluster but from what I have read they are a few different types. I have a small blue screen in my 2013 Titanium which has the following options: Trip, Settings and System check So would like to upgrade to face-lift version. I have forscan license etc so should be able to match the milage as long as the one is I get is less than that mine is at the moment. Anything I else I need to look for? Would I need to run firmware update? Can I get any version or does one have more features? Quote Link to comment Share on other sites More sharing options...
jlawes20389 Posted October 13, 2020 Share Posted October 13, 2020 I recently did this on mine and my partner's cars. I used the ones from the pre-facelift as I believe that using facelift ones will stop either the sound or visual display for the parking sensors, I can't remember which and also the light dimming won't work. I updated the firmware on both with a ucds clone, I wouldn't attempt with an elm327 cable as it will take the best part of a day to update. Quote Link to comment Share on other sites More sharing options...
DaSingh Posted October 13, 2020 Author Share Posted October 13, 2020 I have a ELS27 which I used to update firmware on APIM and ACM would that do? Is there much difference between the mk3 and mk3.5 cluster? I don't want to lose any features as I have just got my sync3 system all up to date and working correctly Quote Link to comment Share on other sites More sharing options...
jlawes20389 Posted October 13, 2020 Share Posted October 13, 2020 I am not 100% sure with an ELS27 cable to be honest. I haven't used one myself. In this thread there's some great info by Wilco regarding the clusters along with some info about MK3.5 and MK3. https://www.fordownersclub.com/forums/topic/75747-mk3-instrument-cluster-swap/#comments 1 Quote Link to comment Share on other sites More sharing options...
DaSingh Posted October 13, 2020 Author Share Posted October 13, 2020 20 minutes ago, jlawes20389 said: I am not 100% sure with an ELS27 cable to be honest. I haven't used one myself. In this thread there's some great info by Wilco regarding the clusters along with some info about MK3.5 and MK3. https://www.fordownersclub.com/forums/topic/75747-mk3-instrument-cluster-swap/#comments Thanks looks like I need a mk3 2012-2014 level 3 cluster to save time changing the software. If I find one at a decent price I think I will do it. Quote Link to comment Share on other sites More sharing options...
jlawes20389 Posted October 13, 2020 Share Posted October 13, 2020 I got lucky with the two I purchased as I didn't check the mileage on them and they were low enough for my needs and I got them for £25 and £30. I did have this one in my eBay watch list, not sure of the mileage as I didnt ask. https://www.ebay.co.uk/itm/254624900224 May be worth checking out? 1 Quote Link to comment Share on other sites More sharing options...
DaSingh Posted October 13, 2020 Author Share Posted October 13, 2020 The problem I have is my car is low mileage so need to find below 35k Quote Link to comment Share on other sites More sharing options...
DaSingh Posted October 22, 2020 Author Share Posted October 22, 2020 Is anyone able to help with milage correction? Just bought a cluster but seller doesnt know the mileage so assuming its high. Quote Link to comment Share on other sites More sharing options...
jlawes20389 Posted October 23, 2020 Share Posted October 23, 2020 I think you'll need someone with ucds if it's too high. Where are you located, somebody local may have it and be able to do it? Quote Link to comment Share on other sites More sharing options...
JW1982 Posted October 23, 2020 Share Posted October 23, 2020 Or buy yourself a Chinese UCDS clone for less than €20,-. 1 Quote Link to comment Share on other sites More sharing options...
DaSingh Posted October 23, 2020 Author Share Posted October 23, 2020 2 hours ago, jlawes20389 said: I think you'll need someone with ucds if it's too high. Where are you located, somebody local may have it and be able to do it? Nottingham 25 minutes ago, JW1982 said: Or buy yourself a Chinese UCDS clone for less than €20,-. Anything in particular to look out for on aliexpress? Is 35 tokens enough? Quote Link to comment Share on other sites More sharing options...
Frowma Posted October 23, 2020 Share Posted October 23, 2020 Make sure you ask the seller to say it is a gift, I've forgotten to do that in the past and have been hit with a customs charge, it's not the customs charge I mind (they've only been a couple of quid) it's the £8 default fee the post office charge for paying it for you that I resent! 1 Quote Link to comment Share on other sites More sharing options...
DaSingh Posted October 28, 2020 Author Share Posted October 28, 2020 Cluster came today, took 5mins to swap... Everything seems to be working, including satnav directions on cluster... Just waiting for ucds and will do firmware update too Quote Link to comment Share on other sites More sharing options...
DaSingh Posted October 28, 2020 Author Share Posted October 28, 2020 If you update ipc software do you lose reverse sensors beeps? Wouldn't mind digital speedometer but not if its going to mess with other stuff Quote Link to comment Share on other sites More sharing options...
JW1982 Posted October 28, 2020 Share Posted October 28, 2020 When updating the instrument cluster in a Focus MK3 to MK3.5 software you will loose the sound of the reverse sensors and in case of Active Park Assist you will loose both the sound and the visual image on the FCDIM. The only way to solve this is by installing a MK3.5 PAM (Parking Assistance Module). In case of Active Park Assist you also need to install 2 additional parking sensors at the side of the rear bumper. Quote Link to comment Share on other sites More sharing options...
DaSingh Posted October 28, 2020 Author Share Posted October 28, 2020 Oh wow that's not good! So the digital speedo is only on mk3.5? I will probably just update the standard software only as I don't want to lose anything. Any ideas what the mk3.5 PAM and the extra sensors part numbers are? At least I can work out if its worth doing 🙂 Quote Link to comment Share on other sites More sharing options...
JW1982 Posted October 28, 2020 Share Posted October 28, 2020 The digital speedometer is indeed only present on the MK3.5 software. The MK3 software did never had this functionality. Very late Kuga MK2's did have a digital speedometer but the Kuga did have a different instrument cluster from the Focus Mk3. The Kuga MK2 instrument cluster can be installed into a Focus MK3 with only a minor modification. To convert the MK3 Active Park Assist system to the MK3.5 Active Park Assist system you need the following parts: 1x PAM module Finis 2125320 Part number F1ET-15K866-BJ Price €62,79 1x Wiring harness Finis 2120207 Part number F1ET-15K868-ALE Price €47,22 2x PDC sensor Finis 1911179 Part number F1ET-15K859-AA Price 2x €39,85 2x Ring transparant Finis 1911177 Part number EM2T-15B864-BA Price 2x €12,24 2x Sensor bracket Finis 1904899 Part number F1ET-15K870-EAXUAA Price 2x €12,06 1 Quote Link to comment Share on other sites More sharing options...
DaSingh Posted October 28, 2020 Author Share Posted October 28, 2020 Thanks for quick reply! For now I don't think I will be doing this. I will probably just update the current to the latest available and look at adding a custom vbf to make it a look a bit better. Quote Link to comment Share on other sites More sharing options...
JW1982 Posted October 29, 2020 Share Posted October 29, 2020 I want to perform this modifications myself on my car. Next time I have to order spare parts for my car I also order the parts to retrofit the MK3.5 PAM module. I currently use a modified version of the latest MK3 instrument cluster software with animated RS logo 1 Quote Link to comment Share on other sites More sharing options...
DaSingh Posted November 3, 2020 Author Share Posted November 3, 2020 I have just noticed the remain fuel on the quad screen seems to be higher. Just to test I wait for orange fuel light to come on which is normally 50miles left and currently it's showing 100miles. I thought the cluster came from same engine car but looking back at this listing it just says petrol manual. Can this be corrected using forscan? Quote Link to comment Share on other sites More sharing options...
JW1982 Posted November 4, 2020 Share Posted November 4, 2020 The "Miles to empty" calculation and the activation of the orange fuel light is adaptive. These values are calculated based on average fuel consumption, actual fuel consumption, driving style, outside temperature, engine temperature, etc. When an instrument cluster from a different car with a different engine type is installed the "Miles to Empty" calculation and the activation of the orange fuel light are still based on the original vehicle the instrument cluster came from. The memory that has this information stored can not be erased or reset. During time the instrument cluster will adapt itself to the new situation. On a low mileage cluster this process will be a lot faster than on a high mileage cluster. 1 Quote Link to comment Share on other sites More sharing options...
DaSingh Posted November 4, 2020 Author Share Posted November 4, 2020 Ignore me! I was looking at the wrong quarter! Flicked through the trip screens and it was correct 🤦 Quote Link to comment Share on other sites More sharing options...
DaSingh Posted November 8, 2020 Author Share Posted November 8, 2020 All done! Got my ucds fixed the mileage... Going to try apply a new theme soon other than and need to add compass direction to ipc too. Quote Link to comment Share on other sites More sharing options...
JW1982 Posted November 8, 2020 Share Posted November 8, 2020 The Compass will only work if your car has a GPSM module. On the Focus MK3 the GPSM module is only present on cars that have SYNC 1.0/1.1 with Emergency Assistance. 1 Quote Link to comment Share on other sites More sharing options...
Guest Posted March 15, 2021 Share Posted March 15, 2021 On 10/28/2020 at 8:58 PM, JW1982 said: The digital speedometer is indeed only present on the MK3.5 software. The MK3 software did never had this functionality. Very late Kuga MK2's did have a digital speedometer but the Kuga did have a different instrument cluster from the Focus Mk3. The Kuga MK2 instrument cluster can be installed into a Focus MK3 with only a minor modification. To convert the MK3 Active Park Assist system to the MK3.5 Active Park Assist system you need the following parts: 1x PAM module Finis 2125320 Part number F1ET-15K866-BJ Price €62,79 1x Wiring harness Finis 2120207 Part number F1ET-15K868-ALE Price €47,22 2x PDC sensor Finis 1911179 Part number F1ET-15K859-AA Price 2x €39,85 2x Ring transparant Finis 1911177 Part number EM2T-15B864-BA Price 2x €12,24 2x Sensor bracket Finis 1904899 Part number F1ET-15K870-EAXUAA Price 2x €12,06 I have fitted the MK 3.5 cluster to my 2012 C Max. As expected I have lost my Park Assist chimes (I only have rear sensors), mileage correction was straightforward (FORScan). If I change My PAM I'm guessing these will come back. However I noticed a far more concerning problem that after configuration with Focccus writing o BCM was fine but writing to IPC caused many issues (engine light etc) and wouldn't complete, leaving the car inoperable. Fortunately I was enable to recover from backup. I haven't tried to write to ICP since. Is this normal and if so can it be fixed. Thanks in advance for any help offered. Quote Link to comment Share on other sites More sharing options...
