Baileymex Posted October 16, 2020 Share Posted October 16, 2020 HI all Random question, do you think it is possible to 'code' the front Fogs of a 2016 Sport to be on all the time and act as DRL's? or would it have to be a hard wire job? Pop in a decent LED bulb and may look a lot better than the candles that are in the standard halogen headlights Thanks in advance Quote Link to comment Share on other sites More sharing options...
simonb65 Posted October 16, 2020 Share Posted October 16, 2020 Just pop LEDs in place of your Halogens, makes everything better (and easier than coding changes). Quote Link to comment Share on other sites More sharing options...
Baileymex Posted October 16, 2020 Author Share Posted October 16, 2020 That was going to be my next job, but just thought having a stand alone DRL lower in the bumper might look just as good if not better, didn't really want to hack about looms, so wondered if there was coding that could make the Fog light run when the engine is started? Quote Link to comment Share on other sites More sharing options...
simonb65 Posted October 16, 2020 Share Posted October 16, 2020 Don't forget the front fog are cornering lights, not just fogs, so it makes the logic a bit more complex if you expect them to be DRLS! In the US/Canada, they have lights (DRLS??) on the fog surrounds, where we get a chrome trim. Quote Link to comment Share on other sites More sharing options...
Baileymex Posted October 16, 2020 Author Share Posted October 16, 2020 2 minutes ago, simonb65 said: Don't forget the front fog are cornering lights, not just fogs, Are they? I didn't realise that, mind you I wouldn't have seen that when driving, might give it a go later. Cheers for the heads up Quote Link to comment Share on other sites More sharing options...
simonb65 Posted October 16, 2020 Share Posted October 16, 2020 I think they kick in at less than 18mph, above that they both revert to whatever the front fogs are set to. Quote Link to comment Share on other sites More sharing options...
Baileymex Posted October 16, 2020 Author Share Posted October 16, 2020 Learn something new every day!! Thanks Quote Link to comment Share on other sites More sharing options...
Hamster Posted October 16, 2020 Share Posted October 16, 2020 Also, they are the wrong position for DRL and would invalidate the homologation data for the European Edge. They used to be called the construction and use regulations and almost certainly doing it would be an MOT failure. Don't do it. H 1 Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted October 16, 2020 Share Posted October 16, 2020 Fog lights must not be repurposed as drl as the light output is incorrect plus if they sre still connected to a foglight switch you are breaking the law which states that foglights should not be used unless road visibility is substantially reduced by weather conditions.Far safer and legal to just fit a set of standalone led drl lights elsewhere which have all the correct dedicated wiring and relays in place.Sent from my SM-G965F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Baileymex Posted October 17, 2020 Author Share Posted October 17, 2020 Cheers all, idea binned. Quote Link to comment Share on other sites More sharing options...
