Radio logos
Is there a fix for the radio logos I most of them missing after F9 and 3.4 update would a master reset help
Did you try the solution highlighted in  the discussion on the Sync3  maps F9 thread - October 4th around page 37 ?
This worked for me and very easy to do.
I’m not good with computers is there an easier way off doing it
That's the easiest/only way ... can you get help from someone ? The post from @colinmcg71 at the top of page 37 has all you need
I'm not sure about the logos but after updating to 3.4 with f9 maps I didn't have many dab stations available and the ones I could receive didn't have great coverage while driving. After a day or two I had more stations available and the local ones I use all have logos now.
I’ve had the new version on for a while now and none of the logos have appeared I wonder how come ColW logos appeared
Does that look correct for DAB logos do you need to unzip the auto install and and the other file
I don’t understand stand this Installing this requires the creation of a simple one item autoinstall.lst file. (Attached below, change file extension from .txt to .lst (LST)
Hi Dave, I’ve edited my post to include a direct link the the autoinstall.lst file. No need to edit file names.
 You have the correct DAB logo file and it doesn’t need to be unzipped.
On your USB drive create a folder called SyncMyRide and copy the logo file in here.
Download the new autoinstall file and copy this to your USB drive too. Make sure it isn’t in the SyncMyRide folder.
You will then be ready to update your logo file.
The picture above is on my usb stick does it correct to you
Yes but the autoinstall file looks like it's still just a text file which won't work. Delete that one and download this https://onedrive.live.com/?authkey=!AGWJAQznWSmct14&cid=3E72313DFB431897&id=3E72313DFB431897!10045&parId=3E72313DFB431897!105&o=OneUp one and copy it to your USB drive.
It should look like this when it's done.
How about that ?
1 minute ago, DaveG1975 said:
How about that ?
Perfect. You are good to go now. Install should take only a minute or two if that.
8 minutes ago, DaveG1975 said:
https://ivsubinaries.azureedge.net/swparts/1U5T-14G658-AE_1553188025000.TAR.GZ
That was the file to download for the logos wasn’t it thats the file I put into SyncMyRide folder
Yes, that's correct the one for Sync 3.4.20136
Even though that's the correct logo file there are still a few missing. Here's a list of stations which don't have a logo:
Magic Musicals
Magic Chilled
HITS RADIO UK
Shared Access
Absolute Radio 70s
talkRADIO
Love SPORT
JACK Radio (UK)
BFBS UK
Sunrise Radio UK
Absolute Rad 80s
Planet Rock
Times Radio (displays talkRADIO logo)
BBC R5LiveSportX (2 stations, one logo missing)
BBC Radio 5 Live
Capital DANCE
Smooth Chill
Gold UK
KISSTORY
Heart 80s
Capital UK
Better check if that’s version I have well it the one I downloaded of the Ford site
Well that’s better than what I have got only got about 2 on there capital work can’t remember the other do you have to do a reboot of sync before it works
Yes you’ll need to power off then lock the doors after install. Unlock again then power on and you should have a lot more logos.
That’s great thanks for all your help I really appreciate it
No problem at all
Exactly!
I only have Apple !
luckily got a bro with a PC and more importantly the knowledge how to work it. What would I do without help from him?
Dealership ?!? Booked in for a week!
Very brave still using Windows 7 this late in 2020 lol.
