Jonson Posted November 10, 2020 Share Posted November 10, 2020 Can anyone tell me the part number for the OEM dab aerial mast on a 2018 mk8 fiesta? Someone has pinched mine and I can't find it online. TIA Quote Link to comment Share on other sites More sharing options...
st line x 140 driver Posted November 10, 2020 Share Posted November 10, 2020 Try this https://www.ebay.co.uk/itm/Genuine-Ford-Aerial-Replacement-Rod-2093355/273420142170?epid=17022899673&hash=item3fa91c465a:g:J6cAAOSw~gZcYW3n Quote Link to comment Share on other sites More sharing options...
Jonson Posted November 10, 2020 Author Share Posted November 10, 2020 Thanks, doesn't look quite the same (dont think mine had the spiral feature on the outside?) and the model checker says it doesn't fit my vehicle...🤔 Quote Link to comment Share on other sites More sharing options...
st line x 140 driver Posted November 10, 2020 Share Posted November 10, 2020 58 minutes ago, Jonson said: Thanks, doesn't look quite the same (dont think mine had the spiral feature on the outside?) and the model checker says it doesn't fit my vehicle...🤔 i have same model 69 reg my aerial has the spiral on it . It has B & O Speakers but wouldn't of thought that would affect aerial. 1 Quote Link to comment Share on other sites More sharing options...
Jonson Posted November 10, 2020 Author Share Posted November 10, 2020 Ok thanks very much 👍 Quote Link to comment Share on other sites More sharing options...
st line x 140 driver Posted November 10, 2020 Share Posted November 10, 2020 Or without spiral https://www.ebay.co.uk/itm/Genuine-Ford-Aerial-Replacement-Rod-2002542/273420305354?_trkparms=aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D225076%26meid%3D0560ce0e0a0e47eba22d50f563db2418%26pid%3D100010%26rk%3D1%26rkt%3D12%26mehot%3Dpp%26sd%3D273420142170%26itm%3D273420305354%26pmt%3D0%26noa%3D1%26pg%3D2047675%26algv%3DDefaultOrganic%26brand%3DFord&_trksid=p2047675.c100010.m2109#vi-ilComp size & fixing both the same more expensive 1 Quote Link to comment Share on other sites More sharing options...
st line x 140 driver Posted November 10, 2020 Share Posted November 10, 2020 £5 off code valid 17/11/2020 for eBay - YUKRT1Q662MW3FQM Quote Link to comment Share on other sites More sharing options...
Mavroz Posted November 11, 2020 Share Posted November 11, 2020 6 hours ago, st line x 140 driver said: i have same model 69 reg my aerial has the spiral on it . It has B & O speakers but wouldn't of thought that would affect aerial. None of ours have an aerial like in the picture..... however my old Ford Focus was like that a few years back. Never seen one on the newer cars. Have you had the car from new? If not it could have been replaced by the previous owner if theirs had gone missing, same as the OP's. Edit... apparently the winding is purely to try and stop vibration and wind noise at certain speeds. Only there to add rigidity. 2 Quote Link to comment Share on other sites More sharing options...
st line x 140 driver Posted November 11, 2020 Share Posted November 11, 2020 Hi Martin ford direct car picked it up with 1.5k on clock. I've only seen cars with spiral on aerial maybe thats why its cheaper being older style / replacement. 1 Quote Link to comment Share on other sites More sharing options...
Jonson Posted November 11, 2020 Author Share Posted November 11, 2020 Thanks both, very helpful. I've gone for the non-spiral version, which the checker says does fit my model in this case. Quote Link to comment Share on other sites More sharing options...
Eng_Ahmad1986 Posted November 12, 2020 Share Posted November 12, 2020 that spiral mast is for the sunroof equipped fiesta only, its also shorter in length by few millimeters , I don't know why ford make this spiral one specially for the sunroof equipped fiesta !! 1 Quote Link to comment Share on other sites More sharing options...
st line x 140 driver Posted November 12, 2020 Share Posted November 12, 2020 28 minutes ago, Eng_Ahmad1986 said: that spiral mast is for the sunroof equipped fiesta only, its also shorter in length by few millimeters , I don't know why ford make this spiral one specially for the sunroof equipped fiesta !! That's good i've a sunroof👌 1 Quote Link to comment Share on other sites More sharing options...
Jonson Posted November 13, 2020 Author Share Posted November 13, 2020 Doh! In that case I've ordered the wrong one after all 🙄 I still don't remember mine having that spiral on it though. Quote Link to comment Share on other sites More sharing options...
st line x 140 driver Posted November 13, 2020 Share Posted November 13, 2020 Don't think you will have any problem panoramic sunroof doesn't interfere with aerial when fully open. Might be due to aerodynamics when open makes it less flexible. 1 Quote Link to comment Share on other sites More sharing options...
anon Posted January 31, 2023 Share Posted January 31, 2023 Pardon my resurrecting this topic but the reason is because the glass roof has no ground plane so the antenna behaves differently to that on a metal roof. 1 Quote Link to comment Share on other sites More sharing options...
