nemmi69 Posted November 25, 2020 Share Posted November 25, 2020 Of course I find out in the bad weather that the screen has suddenly stopped (worked last month). So after reading up on this this is what I have done. 1) Checked the fuses 2) Swapped the relay with the ABS 3) Put a meter on the driver side wires. Power there. 4) Examined connections (see pics) . Cannot see anything obvious. Any ideas? Quote Link to comment Share on other sites More sharing options...
fullwavebridge Posted November 25, 2020 Share Posted November 25, 2020 Mine is now non operational John, it was ok 3 years ago but slowly failed from just half screen to only a few elements working. Again all my fuses - relay etc ok, just put it down to end of it's life and come to the conclusion in my case a new windscreen is required. Probably down to moisture ingress but tbh i do have the screen delaminating in the corners which is a bad sign. After reading up on the ford heated screen via the usual search engines, it is not an uncommon issue. Only way to replace economically would be via insurance should something hit the screen.... Quote Link to comment Share on other sites More sharing options...
Luke4efc Posted November 25, 2020 Share Posted November 25, 2020 As above really. If you've power at the plug then it can only be the screen at fault. Maybe check continuity through the elements. You'll probably find either high resistance or open circuit. Quote Link to comment Share on other sites More sharing options...
Kevan9369 Posted November 25, 2020 Share Posted November 25, 2020 I made a how to guide a few years ago, I think the pictures are long gone now though. Quote Link to comment Share on other sites More sharing options...
nemmi69 Posted November 27, 2020 Author Share Posted November 27, 2020 Well here's a thing. So, disconnected the power connector up by the screen and put the meter inbetween. Showed 14.4V as would be expected. But the screen is still not working. Quote Link to comment Share on other sites More sharing options...
Rogue2 Posted November 28, 2020 Share Posted November 28, 2020 The elements in the screen have probably failed - probably through age or weather related. It won’t matter how much power is at the plug, if the elements are dead - it’s not going to work. 1 Quote Link to comment Share on other sites More sharing options...
fullwavebridge Posted November 29, 2020 Share Posted November 29, 2020 If you disconnected the On 11/27/2020 at 9:01 PM, nemmi69 said: Well here's a thing. So, disconnected the power connector up by the screen and put the meter inbetween. Showed 14.4V as would be expected. But the screen is still not working. meter should be on current (Amps) not voltage range if measuring in line. I think you should accept that the screen is u/s, if all checks have been carried out and you have voltage present at the terminals. Quote Link to comment Share on other sites More sharing options...
nemmi69 Posted November 30, 2020 Author Share Posted November 30, 2020 On 11/29/2020 at 4:56 PM, fullwavebridge said: If you disconnected the meter should be on current (Amps) not voltage range if measuring in line. I think you should accept that the screen is u/s, if all checks have been carried out and you have voltage present at the terminals. Yeah, got that feeling. Seems odd it happened both sides at the same time. Quote Link to comment Share on other sites More sharing options...
fullwavebridge Posted December 1, 2020 Share Posted December 1, 2020 If one common return for both sides has gone open circuit then yes John that's probably the reason. As i previously mentioned mine has failed completely, i just get the car running for 5 min before i finish work at 3am ! Many more little jobs to do to mine, just had cambelt,water pump, aux belt replaced at 120k, i prefer my vaux astra 1.7dti but prefer the £30 ford road tax ! Quote Link to comment Share on other sites More sharing options...
tlo Posted December 14, 2020 Share Posted December 14, 2020 I am in the same boat as you (or should that be car) anyhow the difference with mine is , it was working albeit not very well now the light on the switch has stopped working . I have checked the fuses and they seem ok could you please tell me where and which relay is for the heated front screen ? thank you Quote Link to comment Share on other sites More sharing options...
Confused Confucious Posted December 26, 2020 Share Posted December 26, 2020 Unfortunately ford's Quick Clear screens are problematic. But I did get one fixed for £75. The problem seems to be any stone chips break the heating wires inside. Plus according to the autoglass bloke they delaminate with time and just stop working. Common signs are white/misty around the edges of the screen. Often close to the corners. If your fuses are good and you get power up to the screen then the screen itself needs replacement. Well my fix - I was 'careless' with a set of plyers and accidentally cracked the screen in the passenger area. Autoglass replaced the screen for my £75 glass excess. Afterwards it was all working fine and dandy. Just offering it out there. 1 Quote Link to comment Share on other sites More sharing options...
