Krayze Mc DnB Posted December 6, 2020 Share Posted December 6, 2020 Good evening, so 1st off i would like to say this is my 1st diesel car an was told the clutch is hydraulic, so straight away im lost lol. Basicly i was just on my way to london when i tapped my clutch an it sprung straight down and stayed there. At that time i was able to get a little bit of movement enabling me to change gear but with in 2 mins there was absolutely no use to the pedal at all. The gear box was still engaged as i was able to balance the gears between changes via the revs so it slipped in an out of gear to get me home. what is the issue here as i thought if the clutch had gone it would just rev when in gear. Quote Link to comment Share on other sites More sharing options...
Krayze Mc DnB Posted December 6, 2020 Author Share Posted December 6, 2020 Sorry i ha e a Ford Focus 1.8Tdci 58 plate Quote Link to comment Share on other sites More sharing options...
tommy1340millar Posted December 6, 2020 Share Posted December 6, 2020 Clutch concentric (or slave) cylinder has packed in Quote Link to comment Share on other sites More sharing options...
Krayze Mc DnB Posted December 6, 2020 Author Share Posted December 6, 2020 That what i had read. On scale of 1-10, 10 bein hard. How hard would you say it is s Quote Link to comment Share on other sites More sharing options...
Luke4efc Posted December 7, 2020 Share Posted December 7, 2020 Its a gearbox out job. For someone who doesn't even know what hydraulics are that's an 11/10 in terms of difficulty. You may as well get a new clutch and flywheel fitted at the same time as it won't cost too much more as the box is already out. 1 Quote Link to comment Share on other sites More sharing options...
billyboy Posted December 7, 2020 Share Posted December 7, 2020 Either slave cylinder or master cylinder leaking, not a big job to replace. Quote Link to comment Share on other sites More sharing options...
nicam49 Posted December 7, 2020 Share Posted December 7, 2020 3 hours ago, billyboy said: Either slave cylinder or master cylinder leaking, not a big job to replace. ? Depends if the csc is inside the bellhousing.... Then it IS a big job! 2 Quote Link to comment Share on other sites More sharing options...
