Remove mk8 door card 3dr drivers side
Magicmushroom2005
Hi
i need to remove my mk8 door card,  i have a vibration when Speakers on , top of the door somewhere
its just the window switch pack its hard to
remove i have unclipped the top but the bit by the armrest i cant pull out
thanks
Pain the ***** they are.
Once you've unclipped the nearest edge to you, you need to put a couple of wedges in-between switch pack and door card to force it away a little. Then lift up vertically both ends of switch pack.
29 minutes ago, Eng_Ahmad1986 said:
I found this manual online to remove the window switch unit , hope this helps 🙂
Well done , that shows exactly what I was describing about the wedges.
I've had this off twice and it was a pain each time...wish I had that pdf rather than doing it blind...saved for future reference, thanks Ahmad good find 👍
Thank you to both of you 😊😊
Would it be easier to remove the door card instead or do you need to remove the switch panel to access fixings to remove the card?
Gotta take switch panel off to access screws holding door card to the door unfortunately, its a right pain 😵
Ah - wasn't sure if there was a fixing behind - might have to remove mine as i have a slight buzzing from somewhere near/ behind the pass door panel 😞
Where did you get the window guide from? It their a guide for anything on the fiesta?
On 12/23/2020 at 5:03 PM, Si_ST said:
this may help
Shame he misses the window bit out hahah thanks
This is FORD workshop manual for our mk8 Fiesta
2017-2020 Ford Fiesta 1.0L Ecoboost 6-Speed Workshop Manual - Get Free (cardiagn.com)
if it didn't work try cardiagn.com then select your Brand and Model 🙂
I shared this worskhop manual in a previous post
