chris g Posted May 2, 2010 Share Posted May 2, 2010 hi i've got a 1999 focus and up until last week my fan/blower was working , now its just died on me i have checked the fuses and they all seem fine that's the one under the bonnet and behind the glove box. anyone have any ideas, thanks in advance.. Quote Link to comment Share on other sites More sharing options...
Neilc Posted May 2, 2010 Share Posted May 2, 2010 hi i've got a 1999 focus and up until last week my fan/blower was working , now its just died on me i have checked the fuses and they all seem fine that's the one under the bonnet and behind the glove box. anyone have any ideas, thanks in advance.. Hi Yes a couple of things, does the fan blower work on any setting? If it works on any of 1, 2, 3, or 4 then the common fault is the resistor unit which is located behind the glove pocket to the right of the blower unit and slightly lower, best seen with a torch its a single screw and new ones cost about £15 fron Ford. Other less common faults are the actual rotary switch on the dash board which have been known to go wrong. Hope this helps Neil Quote Link to comment Share on other sites More sharing options...
chris g Posted May 2, 2010 Author Share Posted May 2, 2010 hi i've got a 1999 focus and up until last week my fan/blower was working , now its just died on me i have checked the fuses and they all seem fine that's the one under the bonnet and behind the glove box. anyone have any ideas, thanks in advance.. thanks neil ,no it does not work on any setting Quote Link to comment Share on other sites More sharing options...
stef123 Posted May 2, 2010 Share Posted May 2, 2010 thanks neil ,no it does not work on any setting im sure the older focus' had a problem with the connections to the motor, might be worth checking these. Quote Link to comment Share on other sites More sharing options...
Neilc Posted May 8, 2010 Share Posted May 8, 2010 thanks neil ,no it does not work on any setting Ok It still might just be the resisitor thats at fault for about £15.00 its worth a try, my local Ford dealer keeps these babies in stock so sell so many!!! just locate it remove the wiring plug connect to the new one and try, if it works then remove the old one and replace it its only one screw!!! although access is tight it very straightforward. Neil Quote Link to comment Share on other sites More sharing options...
