Wi1189 Posted January 31, 2021 Share Posted January 31, 2021 Hello all, I've recently noticed that the adaptive headlights on my 2016 focus titanium X turn to the right when I start driving and the high beam won't work, when I pullover and stop they point forward and the high beams then work again. Could it be due to only one headlight working just now? Quote Link to comment Share on other sites More sharing options...
karlbbb Posted February 2, 2021 Share Posted February 2, 2021 Do you get the warning on the dashboard when it happens? Unfortunately this is a common problem, especially with earlier units of the Mk3.5 adaptive lights, and it's a pretty penny to buy a new unit. It can be fixed if you're a dab hand at soldering and the issue is just a broken wire. If things like the connector have been pulled off the PCB, it ain't getting fixed. Quote Link to comment Share on other sites More sharing options...
matt77303 Posted February 3, 2021 Share Posted February 3, 2021 Mines recently started doing this. Noticed the drivers side points to the right *sometimes* when driving. Pulling up to the garage door at night it moves back to the correct position. No errors on the dash, ill look with forscan when I get a chance. Is there a link to the broken wire fix anywhere? Thanks Matt Quote Link to comment Share on other sites More sharing options...
karlbbb Posted February 3, 2021 Share Posted February 3, 2021 8 minutes ago, matt77303 said: Mines recently started doing this. Noticed the drivers side points to the right *sometimes* when driving. Pulling up to the garage door at night it moves back to the correct position. No errors on the dash, ill look with forscan when I get a chance. Is there a link to the broken wire fix anywhere? Thanks Matt There's a couple of pictures in here - first thing to do would be to take the unit off the car and open the back. You'll see the triple wire pretty easily and you may just see one disconnected. As in the linked post above, some get an error, some don't, but seems to be the same underlying issue. 1 Quote Link to comment Share on other sites More sharing options...
matt77303 Posted February 3, 2021 Share Posted February 3, 2021 Brilliant. That's this weekends job sorted. Thank you. Matt Quote Link to comment Share on other sites More sharing options...
Wi1189 Posted February 4, 2021 Author Share Posted February 4, 2021 I don't get any warnings on my dash, I'll have a look at the above issue this weekend while I'm repairing the left. I'll let you know. Many thanks. Quote Link to comment Share on other sites More sharing options...
Wi1189 Posted February 15, 2021 Author Share Posted February 15, 2021 So I've repaired the headlight that was out on the passenger side, first picture was the fault (same issue I had on driver side last year). The original post issue, the headlight seems to have re-synched upon repair of the passenger side, however, I now have a coolant leak, coming from the location in the second picture, am I looking at an expensive repair? Quote Link to comment Share on other sites More sharing options...
matt77303 Posted February 21, 2021 Share Posted February 21, 2021 Finally got round to looking at this. No damaged wires. Bollox Matt Quote Link to comment Share on other sites More sharing options...
marcb Posted December 11, 2022 Share Posted December 11, 2022 For anyone coming across, I had exactly the same issue. Garage quoted me near £1300 for a replacement light. Found this website https://adaptivefix.com/ and ordered a replacement wire for £10 which solved my problem no soldering needed. When I took apart the light I could see one cable had come loose 1 Quote Link to comment Share on other sites More sharing options...
