jrobinson Posted February 1, 2021 Share Posted February 1, 2021 Hi all, I have been experiencing an intermittent engine problem. Sometimes when I come to a junction or leave the clutch in the engine cuts out. It starts again first time and I can continue with my journey. Sometimes it'll happen several times in a row or just once. It is fairly random. I'm not sure if this is related (I presume so however) but when I accelerate the revs go very high and then drop back to normal and the car seems seems underpowered (takes a long time to get up to 70mph on a motorway). Any thoughts on what the problem could be or a solution perhaps? Thanks for your help. I appreciate it. J. Quote Link to comment Share on other sites More sharing options...
jrobinson Posted February 2, 2021 Author Share Posted February 2, 2021 Bit of an update: Not sure if this is related but I went to start the car this morning and it would start. I can hear a single click. All other electrics seem to work but headlights did seem dimmer. This has happened twice before and eventually it just started by itself. Not sure if this is related to the cold and snow overnight. I'm getting a battery charger this afternoon so hopefully I'll at least get it started. Then I can try to start solving the other issues. J. Quote Link to comment Share on other sites More sharing options...
jrobinson Posted February 3, 2021 Author Share Posted February 3, 2021 Update: This morning, I reinstalled the battery which I charged up yesterday. Same problem, just getting a single click which I presume means that the fault must be the starter or electrics to the starter. One anomaly is that during one random attempt to start the car, I got rapid clicking for a second or two which seems very odd (To someone who knows next to nothing about cars/engines). I'm trying to get my brother to drop off a jack today so I get to the starter and try to give it a gentle persuading. Hopefully, one step closure to locating the problem. J. Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted February 3, 2021 Share Posted February 3, 2021 Have you tested the voltage of the battery? It might be beyond charging. Quote Link to comment Share on other sites More sharing options...
jrobinson Posted February 3, 2021 Author Share Posted February 3, 2021 Just now, TomsFocus said: Have you tested the voltage of the battery? It might be beyond charging. Hi Tom, I tested it yesterday before charging and it read 12.25v. Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted February 3, 2021 Share Posted February 3, 2021 7 minutes ago, jrobinson said: Hi Tom, I tested it yesterday before charging and it read 12.25v. And how about after? That rapid solenoid clicking is almost always a battery fault rather than a starter fault. Have you checked the thick battery cables to the starter and gearbox, and made sure the terminals themselves are tight? Regarding the revs rising suddenly but taking a while to reach 70mph, that sounds like a slipping clutch but not relevant for starting of course. 1 Quote Link to comment Share on other sites More sharing options...
jrobinson Posted February 3, 2021 Author Share Posted February 3, 2021 1 hour ago, TomsFocus said: And how about after? That rapid solenoid clicking is almost always a battery fault rather than a starter fault. Have you checked the thick battery cables to the starter and gearbox, and made sure the terminals themselves are tight? Regarding the revs rising suddenly but taking a while to reach 70mph, that sounds like a slipping clutch but not relevant for starting of course. It's showing 13v not that I have charged it. Just to clarify, I only heard the rapid clicking for a second in between loads of attempted starts. Every other attempt either side was met me a single click. Thanks for the advice on the revs. If I sort out this startup problem, I'll move on to your suggestion of slipping clutch. 1 Quote Link to comment Share on other sites More sharing options...
jrobinson Posted February 4, 2021 Author Share Posted February 4, 2021 On 2/3/2021 at 1:08 PM, jrobinson said: It's showing 13v not that I have charged it. Just to clarify, I only heard the rapid clicking for a second in between loads of attempted starts. Every other attempt either side was met me a single click. Thanks for the advice on the revs. If I sort out this startup problem, I'll move on to your suggestion of slipping clutch. Btw, the 13v was right after charging. I've just checked now and its down to 12.48v. Does this imply that I need a new battery? Quote Link to comment Share on other sites More sharing options...
Paulkp Posted February 4, 2021 Share Posted February 4, 2021 I would always leave it for 30 minutes after completing charging before I measured the battery volts, but what does it drop to with your headlights on ? Open circuit voltage is not a good indication of battery condition, as it does not give any information into the internal resistance or capacity. 1 Quote Link to comment Share on other sites More sharing options...
jrobinson Posted February 4, 2021 Author Share Posted February 4, 2021 20 minutes ago, Paulkp said: I would always leave it for 30 minutes after completing charging before I measured the battery volts, but what does it drop to with your headlights on ? Open circuit voltage is not a good indication of battery condition, as it does not give any information into the internal resistance or capacity. Would you believe it, I went out to test the voltage with the headlights on and it started this time! I drove it around the block to see how it ran and all was fine. Parked it up and now it won't start again! haha. Anyway, I took the reading and it's measuring 11.48 with headlights on. Quote Link to comment Share on other sites More sharing options...
Paulkp Posted February 5, 2021 Share Posted February 5, 2021 My Fiesta - a short journey yesterday, first time in a week. Calcium battery. O/C = 12.4V Ignition on = 12.2V (but car not started.) Dip Headlamps = 12V 12.25V is probably about 45% charge depending on temperature. https://www.powerprobetek.com/knowledge/beginning-basic-part-1/ Quote Link to comment Share on other sites More sharing options...
jrobinson Posted February 6, 2021 Author Share Posted February 6, 2021 It seems that this problem was starter motor related as the car does start now that I have changed it. I still need to sort out all the other problems with it to get it tiptop again. Thanks for the help on this. 2 Quote Link to comment Share on other sites More sharing options...
jrobinson Posted May 1, 2021 Author Share Posted May 1, 2021 Final update just to help people experiencing similar problems. It looks like I had a dodgy starter motor and I needed a fuel filter replacement. Once I changed the fuel filter the car regained its power and is not running well again. Thanks for all the help. J. 2 Quote Link to comment Share on other sites More sharing options...
