2007 (MK6) Ford Fiesta Zetec - Starter Motor location
Hi all,
I need to locate the starter motor on my mk6 as it won't start (just a click).  Does anyone have an image/description of its location please?  I've searched online but no joy. I've looked under the bonnet to I couldn't see it.
J.
It's a pain in the ***** to remove! I've removed the three bolts on the right handside (As you look at it from above) but there seems no way to get to the nuts to remove the cables from the back on the starter motor.  There is no way to get them from above and from underneath, there is a plastic housing that doesn't allow a spanner or socket in with ease.  Also even though I've removed the bolts it seems solid, can move it at all. 😕
Lots of extensions and UJs can be helpful, it is tight around the inlet mani though.
It'll be seized in with corrosion, just needs a light tap and it should release with those 3 bolts removed.
  Only 75 emoji are allowed.
  • Create New...
Forums
News
Membership
