jrobinson Posted February 6, 2021 Share Posted February 6, 2021 Hi all, I have just changed the starter motor on my Fiesta MK6 and whilst removing the old one, this cable came off. There is only a limited amount of movement as its housed in a cable tidy with little stretch. I've had a good look round above and below the engine but I can't see anywhere obvious it may have come from. Please can you help identify it? Thanks. J. Quote Link to comment Share on other sites More sharing options...
jrobinson Posted February 6, 2021 Author Share Posted February 6, 2021 Its at the front of the engine by the way, between the manifold and the fan Quote Link to comment Share on other sites More sharing options...
jrobinson Posted February 6, 2021 Author Share Posted February 6, 2021 Just had a reply from a guy on an other forum suggesting it is the oil pressure sending unit. Any idea where this might plug in please? J. Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted February 6, 2021 Share Posted February 6, 2021 oil pressure switch is on the front of the engine block, just under the starter iirc. I don't recognise that plug though so may not be that. Quote Link to comment Share on other sites More sharing options...
jrobinson Posted February 6, 2021 Author Share Posted February 6, 2021 Thanks for your help. It was just behind the oil filter. I managed to reconnect it. I hadn't seen where it came off from as it was set far back. Car is starting now so I'm pleased. Thanks for all your help. J. 1 Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted February 6, 2021 Share Posted February 6, 2021 54 minutes ago, jrobinson said: Thanks for your help. It was just behind the oil filter. I managed to reconnect it. I hadn't seen where it came off from as it was set far back. Car is starting now so I'm pleased. Thanks for all your help. J. Sounds like you've had a productive day!! 1 Quote Link to comment Share on other sites More sharing options...
jrobinson Posted February 6, 2021 Author Share Posted February 6, 2021 I certainly have! There are still a few issues to sort out but I'm very pleased it's working again. Thanks again. 1 Quote Link to comment Share on other sites More sharing options...
