ThePowster Posted February 10, 2021 Share Posted February 10, 2021 Afternoon guys聽馃檪 I hope y'all ok, been a while since I was last in here. OK so firstly, it's cold聽馃ザ聽and I haven't had my front heated screen working ever since I think it fried my alternator. But today I was like, enough already, I can't cope with -3.0掳聽in a morning anymore so I need it working again. I had a look in the fuse box under the bonnet and saw this: So according to the haynes manual I had one missing, I must have taken one out last time when I had alternator issues. So I went to Halfords and picked myself up 2 new 40 amp fuses. First thing I noticed is there is only one pin showing on the left hand fuse, this can't be right surely, can it? Then I noticed further down the fuse box another place for a fuse also had only one pin in it, so maybe it is? Can someone confirm firstly if that is right, the right hand fuse has 2 pins but the left hand only one? *confused* Anyway I banged these in and ... nothing. The light comes on when I press the button for the heated screen but I don't hear the... * click * that I used to hear and it's not having it. So what is responsible for the click, is it a switch or a relay? I can't find any info on it in the manual. What would you guys be checking next after replacing these two 40amp fuses? And if there is a relay does anyone know where to buy them and where they are located and I'll get on it. Keeping um crossed it's an easy fix and I will only use it sparingly and I'll scrape windows first and keep some revs on when I do fire it on and take it for a good drive after because I hear that using the heated front screen is a battery killer. Thanks聽in advance fellas 馃檪 Quote Link to comment Share on other sites More sharing options...
ThePowster Posted February 10, 2021 Author Share Posted February 10, 2021 https://ibb.co/QjpGM1X Quote Link to comment Share on other sites More sharing options...
ThePowster Posted February 10, 2021 Author Share Posted February 10, 2021 Oops I installed them wrong haha聽馃槉 This is the fuses in the right place. However, no joy, the light comes on the front heated screen button on the dash but no 'Click!' I tried the rear, that works and the click which I am guessing is a relay, well the sound is coming from the passenger footwell. Am I right in assuming that the relay is the fault and that is also located in the passenger footwell? Again if anyone knows of a link or a part number and location, would help me out no end. Thanks in advance 馃檪 Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted February 10, 2021 Share Posted February 10, 2021 Are you sure the battery is good enough?聽 Front screen takes a huge amount of power so usually the first thing to be cancelled when the battery is low. 2 Quote Link to comment Share on other sites More sharing options...
ThePowster Posted February 10, 2021 Author Share Posted February 10, 2021 I think so Tom. I am fathoming it bit by bit. I think the relay is R7 under the bonnet, I have pulled mine out, I rang Ford they want聽拢48 for it. Found it here for 拢7.98 -聽https://www.citycarparts.co.uk/land-rover-ford-multi-use-grey-relay-12v-70a-fomoco-5m5t-14b192-ea-has-4-pins-14219-p.asp But I would prefer a more reputable brand, not sure if this one fits:聽https://www.buycarparts.co.uk/hella/13668602 Nor am I sure if the one I pulled out my car was original, it's branded FOMOCO. I don't think Halfords do them so I guess I will have to order one online. If this doesn't fix it I ain't sure what else is left to try. It used to work fine until my alternator packed in, then I was pressing it one day and the clicks just stopped clicking lol so I am thinking it has to be this relay. My battery is overkill for this car, cost me like 拢110 when I bought it, then again it's about 5 years old now. 1 Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted February 10, 2021 Share Posted February 10, 2021 FoMoCo is Ford Motor Company so that will be original. Are either of the other 2 grey ones the same?聽 If so, swap one with the heated screen...screen should work, other item should not...聽 Quick free test! The battery could just be low from little use btw, not suggesting the battery itself isn't up to the job. 1 Quote Link to comment Share on other sites More sharing options...
ThePowster Posted February 10, 2021 Author Share Posted February 10, 2021 That's a cracking idea! I've checked and one has a diff number stamped on it so I best not risk it, but it would never have occurred to me to try lol something as simple as that, thanks for the tip I'll try and remember it for next time. Also didn't know what FoMoCo stood for, in that case if it's original Ford I'll get one of those ordered online and save myself 拢40 than going to a Ford dealer lol. Thanks a lot! I'll report if the relay and fuses did the job 馃檪 1 Quote Link to comment Share on other sites More sharing options...
ThePowster Posted February 17, 2021 Author Share Posted February 17, 2021 Morning guys. So I purchased one of those FoMoCo relays second hand from Evilbay, mine rattles when you shake it, the new one doesn't. Anyway I popped it in the car, fired her up, gave it some gas at idle, hit the fronted heated screen button and... nothing, still no 'click' like I get when I click the rear heated screen button. I am hearing the click in the passenger footwell for the rear but the main relay for the front is in the main fusebox under the bonnet, that being said I still used to hear a click when I hit the switch. So with that R7 relay replaced and no joy, what would be the next logical thing to check? Is there anything in the passenger footwell that relates to the front heated screen. Stuck now *sobs* if anyone has any info be very much appreciated. Thanks in advance 馃檪 Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted February 17, 2021 Share Posted February 17, 2021 You need to test whether power is reaching the relay connector when the button is pressed. 1 Quote Link to comment Share on other sites More sharing options...
ThePowster Posted February 17, 2021 Author Share Posted February 17, 2021 Ah good idea. OK so ... hmm I have a multimeter, is it a case of getting someone to press the button on the dash and me use the multimeter to see if I get any current when putting the multimeter prong in the ports? Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted February 17, 2021 Share Posted February 17, 2021 3 minutes ago, ThePowster said: Ah good idea. OK so ... hmm I have a multimeter, is it a case of getting someone to press the button on the dash and me use the multimeter to see if I get any current when putting the multimeter prong in the ports? You can do it on your own.聽 Pull the relay.聽 Switch the engine and heated screen on.聽 Then touch one probe to any earth and the other to the relay connector pins in turn.聽 Test for DC voltage, one pin should be live聽with the screen switched on.聽 (You can work it out from the relay diagram, but it's probably quicker just to poke them all lol) 聽聽 聽 1 Quote Link to comment Share on other sites More sharing options...
ThePowster Posted February 17, 2021 Author Share Posted February 17, 2021 lol that's awesome, so much easier that way, thanks Tom, I'll get on that 馃檪 1 Quote Link to comment Share on other sites More sharing options...
mjt Posted February 18, 2021 Share Posted February 18, 2021 22 hours ago, TomsFocus said: Test for DC voltage, one pin should be live聽with the screen switched on Two pins should be live with the screen switched on, one for the relay coil and the other for the screen supply contact. 2 Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted February 18, 2021 Share Posted February 18, 2021 10 minutes ago, mjt said: Two pins should be live with the screen switched on, one for the relay coil and the other for the screen supply contact. Good point, I stand corrected. 聽 Quote Link to comment Share on other sites More sharing options...
ThePowster Posted February 18, 2021 Author Share Posted February 18, 2021 Thanks Mike / Tom, super grateful for your knowledge!聽馃憤 Quote Link to comment Share on other sites More sharing options...
J0hn Posted February 19, 2021 Share Posted February 19, 2021 My whole heater unit stopped working. I disconnected the battery for ten mins, reconnected and it worked.聽 Just saying. . Switch it off and switch it on again sometimes works.聽 Quote Link to comment Share on other sites More sharing options...
ThePowster Posted February 20, 2021 Author Share Posted February 20, 2021 Thanks John. I have tried that mate before and no joy this time unfortunately. So I have been out today with the multimeter and this was my findings: 4 female contact points which accept the relay starting clockwise at the top, 1-4 ports. Key:聽1 - Top. 2 - Right. 3 - Bottom. 4 - Left. 聽 No ignition 1. 0.00v 2. -0.00v 3. -0.00v 4. 0.89v depleting rapidly 聽 Ignition on聽 1. 0.89v depleting聽rapidly 2. -0.02v 3. 1.06v depleting聽rapidly 4. 1.01v depleting聽rapidly 聽 Front screen button pressed聽 1. 0.02v 2. 0.02v 3. 1.01v depleting聽rapidly 4. 0.90v depleting聽rapidly 聽 Pic above shows how multimeter was set. Initially I had the red wire of the multimeter in the far left hand port of the multimeter where it says 10ADC and the black one to the right hand side next to it. I wasn't getting any readings so I fetched a AA battery and got it plugged in above which is correct and showed 1.5v of a AA bat so I knew it was right then. Above is where I had the negative clip of the negative terminal for the multimeter on this bracket. Image above shows how I did it to begin with, straight from the negative terminal and I got a spark on far left 4 female connector when I put the red multimeter point on it, not sure if this means anything or not. So... Where do we go from here? This R7 relay is in the main engine fuse box as are the two other fuses which have all been replaced, still no 'click' when I hit the button on the dash like I hear from the button when I hit the rear screen demister thing. Is there any more relays and fuses relating to the switch in the car which does light up but nothings happening, from there to make the front heated screen come on. The last time it worked was when my alternator packed in. I replaced it and it's not worked since. It was like something perhaps blew before my alternator packed in, I remember pressing the button, click, on .. click yep worked again, and during that day I pressed it, no more click, no more heated screen *sobs*. 聽 Quote Link to comment Share on other sites More sharing options...
pcaouolte Posted February 20, 2021 Share Posted February 20, 2021 When you got the spark with the meter connected up to measure amps rather than volts you probably blew a fuse in the car and possibly also one in the meter, all readings after that are suspect until the blown fuses are聽replaced. Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted February 20, 2021 Share Posted February 20, 2021 Oops...聽 As above, may have popped the fuse.聽 You were right first time with the neg location, unpainted metal gives less resistance for a more accurate reading.聽 While you've got the fuse out, I'd also check for 12v reaching the fuse connector. Quote Link to comment Share on other sites More sharing options...
mjt Posted February 20, 2021 Share Posted February 20, 2021 As Tom says, you need to make sure you connect the negative lead to unpainted metal. That bracket you used is painted and won't give a good contact. The tag at the end of the battery earth lead at the top of your photo would give a more reliable connection. When you clip it on hold it shut and give it a wiggle to break through any oxidation. Those voltage readings look very abnormal. I would not expect to see a declining voltage. That's what you'd get from a discharging capacitor and there shouldn't be anything like that in the circuit. As Paul has said you may have blown a fuse in your meter or even caused damage to it by using the 10A current input but you can easily check that. With your negative lead clipped to the battery earth point can you read voltage (around 12V) on the battery positive post? I have a feeling that only the current ranges are usually fused anyway so it should still work on voltage. Quote Link to comment Share on other sites More sharing options...
ThePowster Posted March 15, 2021 Author Share Posted March 15, 2021 聽 Morning guys. Taken me ages to put this together, pant, pant.. So I have taken a video which I hope is linked above, but to save you time of watching it I have taken snapshots at all points to show you what kind of voltages I am getting. Firstly you guys were right about finding a proper earth point, well done on identifying that! My voltage wasn't declining once I had the multimeter set correctly and had the earth wire to a proper earth, I'm pleased someone knows what their doing haha. As for the rest of it, I think it looks right, it doesn't appear to me any fuses have blown. The only thing that looks odd to me is the values from ignition on which should actually have said engine running, and engine running with the front screen button on, in this instance (pic 2 and pic 3) I actually lose voltage in the top prong for enabling the switch, but all 3 have power when the switch isn't even pressed. I am not sure what the switch does, there is a pic of the workings of it at the start of the video. Does this make sense to anybody? If this was your car and you were at this stage, aside from taking a hammer to it 馃槥聽what would be your next line of investigation? Thanks again in advance 馃檪 聽 聽 聽 Quote Link to comment Share on other sites More sharing options...
StephenFord Posted March 15, 2021 Share Posted March 15, 2021 4 minutes ago, ThePowster said: Does this make sense to anybody? If this was your car and you were at this stage, aside from taking a hammer to it 馃槥聽what would be your next line of investigation? 聽 Personally, my next line of action would be to take it to an auto spark! Yes, there's much to be said about curing the fault yourself, but there comes a time when you just want the darn thing fixed! You could watch him if you want and consider it a paid for lesson LOL Quote Link to comment Share on other sites More sharing options...
ThePowster Posted March 15, 2021 Author Share Posted March 15, 2021 lol I wish I had dolla for that, save me messing about. Part of me is like this is me vs Focus now, principle thing, need to fathom it lol but yes I hear ya, be better to let a pro sort it if I could. I was hoping it would be an easy fix, so far though it's baffling聽馃く Quote Link to comment Share on other sites More sharing options...
StephenFord Posted March 15, 2021 Share Posted March 15, 2021 5 minutes ago, ThePowster said: lol I wish I had dolla for that, save me messing about. Part of me is like this is me vs Focus now, principle thing, need to fathom it lol but yes I hear ya, be better to let a pro sort it if I could. I was hoping it would be an easy fix, so far though it's baffling聽馃く If you lived in central London, yes, it would be horrendously expensive. I'm lucky, I live in a pretty rural area, and have been using the same 'spark' for 25 odd years, he's brilliant, and not expensive at all. I'd be shocked if he could nort diagnose, and even fix the fault (barring an expensive part!) for more than 拢30. However, I appreciate there will be a wide range of charges around the country... Heated screens are not cutting edge technology, my 1990 RS Turbo had one! Quote Link to comment Share on other sites More sharing options...
