SMax14 Posted February 10, 2021 Share Posted February 10, 2021 Hello My simple question is, can a blocked DPF vaporising valve present as a blocked DPF filter, i.e. if the valve was blocked would this prevent a re-gen or would it mean that the whole DPF was blocked? Thank you! Quote Link to comment Share on other sites More sharing options...
Frembrit Posted February 10, 2021 Share Posted February 10, 2021 If the vaporiser is blocked then the system cannot perform a regen and eventually the DPF will get blocked. The car will go into limp mode at some point if it keeps failing and the DPF fills up to a point (approx. 150 - 180% from my experience, from memory). If the vaporiser is then changed and the DPF learned values are reset, then the system should start to regen when driving normally, providing the DPF wasn't too full (mine was upto 200% and it did a regen) Quote Link to comment Share on other sites More sharing options...
SMax14 Posted February 16, 2021 Author Share Posted February 16, 2021 Thanks so much! Quote Link to comment Share on other sites More sharing options...
