Highest voltage
Hi. I need to know what’s the highest voltage a Ford Focus 1.6 TDCI 2007 can handle? (Electrical like ECU, airbag module, fuel pump electrical and other electrical stuff)
Intriguing...  What are you trying to do?
The SmartCharge can raise the voltage up to about 16v safely.
The question is too vague.
"Spark plugs usually require voltage of 12,000–25,000 volts or more to "fire" properly, although it can go up to 45,000 volts"
https://en.wikipedia.org/wiki/Spark_plug#:~:text=Spark plugs usually require voltage,hotter and longer-duration spark.
I am using this car for car audio. I tricked the internal voltage regulator into thinking the battery is discharged by putting diodes on the red wire that goes into regulator by that harness. Needed that 15v+ for a lithium LTO Yinlong bank. At cold is charging 15.7-8v, so I wanted to know if I am safe; so far no problems showed.
Why you're not simply using DC-DC converter (for LTO charging)? 12V to 16V DC (or whatever LTO charging circuit requires).
