Vokesie Posted February 17, 2021 Share Posted February 17, 2021 Hi I have a 2018 Mk4 focus ST Line. Should the radiator fan run continuously. It turns on 20-30 second after the engine is started and turns off when the auto stop/start kicks in or engine is turned off is this normal if not anyone know how to stop it Quote Link to comment Share on other sites More sharing options...
m50e30 Posted February 17, 2021 Share Posted February 17, 2021 Do you have the aircon on all the time? Quote Link to comment Share on other sites More sharing options...
Vokesie Posted February 17, 2021 Author Share Posted February 17, 2021 2 minutes ago, m50e30 said: Do you have the aircon on all the time? Hi m50e30, thanks for the quick reply Nope everything is turned off Quote Link to comment Share on other sites More sharing options...
m50e30 Posted February 17, 2021 Share Posted February 17, 2021 Sounds like a faulty thermostat or switch 1 Quote Link to comment Share on other sites More sharing options...
Vokesie Posted February 17, 2021 Author Share Posted February 17, 2021 3 minutes ago, m50e30 said: Sounds like a faulty thermostat or switch Thanks. I will persist with Ford then who seems to think it’s ok. only have 6months left on warranty I’m hoping that it will be covered Quote Link to comment Share on other sites More sharing options...
m50e30 Posted February 17, 2021 Share Posted February 17, 2021 Deffo. It's not right 1 Quote Link to comment Share on other sites More sharing options...
Alex.S Posted February 17, 2021 Share Posted February 17, 2021 1 hour ago, Vokesie said: Hi I have a 2018 Mk4 focus ST Line. Should the radiator fan run continuously. It turns on 20-30 second after the engine is started and turns off when the auto stop/start kicks in or engine is turned off is this normal if not anyone know how to stop it I’ve not noticed the 20 seconds delay coming on but definitely turns off when the S/S kicks in. 1 Quote Link to comment Share on other sites More sharing options...
Vokesie Posted February 18, 2021 Author Share Posted February 18, 2021 4 hours ago, Alex.S said: I’ve not noticed the 20 seconds delay coming on but definitely turns off when the S/S kicks in. Is yours on all the time too? Quote Link to comment Share on other sites More sharing options...
Sylvain8992 Posted May 25, 2022 Share Posted May 25, 2022 hello sorry for the writing I am French, have you solved your problem? I have exactly the same vehicle in ecoblue 150, and I have the same problem as you, Ford wanted to change the active grille for me, supposedly blocking it, but it works perfectly Quote Link to comment Share on other sites More sharing options...
