Andi76 Posted February 19, 2021 Share Posted February 19, 2021 Hi all. Recently I discovered that my crankshaft pulley is really wobbly. Now to get one is not a problem,, but i cant find any info about the pulley bolt torque setting. Did anyone changed their pulley and if so what is the torque that the bolt has to be tightened up to? I have a mondeo mk4 57 plate,, 2.0 Tdci 140HP.. Quote Link to comment Share on other sites More sharing options...
Frembrit Posted February 19, 2021 Share Posted February 19, 2021 From the Haynes manual... Stage 1: 70Nm Stage 2: Angle-tighten a further 70o Though if the bolt has become loose or you need to remove to change the pulley then it's recommended to get a new bolt. 1 Quote Link to comment Share on other sites More sharing options...
Tizer Posted February 19, 2021 Share Posted February 19, 2021 I agree with the above regarding renewing the bolt, it may have been off before and has stretched. Also if you don't have a thread cleaning tap it would be a good idea to make 4 cuts with a hacksaw at right angles to the thread, clean them up and screw that in a few times to clean up any old thread locking compound that might be there otherwise it may loosen no matter how far you tighten it up. 1 Quote Link to comment Share on other sites More sharing options...
Andi76 Posted February 19, 2021 Author Share Posted February 19, 2021 Thank you. At the end i wont have to replace the pulley bcs the problem i have is somewhere else, but its always good to know. Quote Link to comment Share on other sites More sharing options...
