Front drop link
How do I remove drop link arm from front strut..when the Allen key head has rounded
Maul grips👍
I can get hold off the Allen head as there is a bolt that has to come off. And the rounded Allen head is supposed to supposed to stay held while the bolt is loosened off.but as the Allen head has rounded ..both are just spinning....
Grip the rounded Allen bolt with maul grips and then undo the other side👍
The bolt and Allen head are on the same side..its a bush thats on the other side??
Photo?👍
I've took 2 pics..but can't seem to send them on here??
grinder
Seems the only way but then will need to buy 2 new drop links as I think the other side will be the same...
I would give it a go with maul grips first if they can grip around.If not and you are confident enough to use a grinder then as said before that’s also an option👍
Cheers guys
there cheap enough to buy 🙂
I once used Dremel with a grinding stone and it melted the bolt off Practically 🙂
