ranger 3.2 abs light /hill descent malfunction esc service
hi my 2017 3.2 ranger is showing abs light /hill descent malfunction /pilot park and esc service required anyone else had same issue my mechanic put scanner on it and it shows abs module
  • 2 months later...
On 3/2/2021 at 8:52 PM, NICK211 said:
There will a broken wire in the rear left conduit from chassis to truck. It’s maybe orange and white.
i have this issue also and I found the cable damaged with movement
get me on Instagram if you have issues finding it
@kanashiboy_
You’ll need an 8mm socket, remove both cable Pclips, remove cables from plastic sleeve and check slowly for green power (copper rust)
if you find that. Cut the wire, bare, clean with sand paper and resolder/ crimp and check for resolved issue
  • 10 months later...
Hi there
do you have more pics or descriptions for this
is it the working loom behind the passenger rear arch liner ?
thanks
joe
