Dpf enquiry
Marty...
Hello,I have done some searching but cannot find a clear answer...would someone in the know be kind enough to advise(or link me to) on wether my dpf uses eolys.
On my V5c,
Focus 2008-, 1.6L Duratorq TDCi (110PS) - DV6, Ocean Blue (copied from ford etis)
Variant:G8DD1P
Version:5KAC MH
Thankyou
2009 is the changeover year from Eolys to cDPF.
If you can post a picture I'll tell you which you have.
Thanks Tom will do so tomorrow,had a look today with engine cover on, up and above right of the alternator,a big can with a heat shield and three wired sensors,do both eolys and cdpf use a sensor located at the battery?
thanks
Both use the pressure sensor at the battery with 2 rubber pipes.
But if you've got 2 temp sensors on the DPF with the blue wiring, that's a cDPF.  Eolys only has one temp sensor in the middle.
  • Like 2
Yes blue wiring,does that mean no fluid required? 😁
Thanks Tom 👍
Thanks Tom 👍
Yep!!  No fluid to worry about and far more reliable too. :biggrin:
  • Thanks 1
You sir have made my day 👍
Marty
  • Like 2
