help...focus mk3 heat pads
hi, ive got a mk3 2012 focus, with the heated seat plugs in the harness under the seats, i have fitted heat pads to my seat and tapped into the live from the plug but earthed out to the body,
should i have used the ground from the harness plug,
as ive got some U faults showing..
If you're using the original wiring you'll also need the switches for the dash.
