joshdowns29 Posted March 8, 2021 Share Posted March 8, 2021 Hi, just ordered new bearings and conrod bolts for MK7.5 ST180. 聽 I just need the torque specs for the bolts, I have tried asking ford themselves but they said they could not give them to me, hoping someone here has the correct torque specs before I go ahead and put them in. 聽 Thanks 馃檪 Quote Link to comment Share on other sites More sharing options...
iantt Posted March 8, 2021 Share Posted March 8, 2021 Ford dealers are right. There is no info on fords workshop manuals . Doesn't specify any engine block dismantling.聽 1 Quote Link to comment Share on other sites More sharing options...
JW1982 Posted March 8, 2021 Share Posted March 8, 2021 Ford considers the bottom end to be unserviceable. Both technical information or internal parts of the bottom end聽are not available from ford. These bolts are TTY (Torque To Yield) and require a very specific torque and angle. The manufacturer or seller聽of the bolts should specify the recommended torque / angle values. 2 Quote Link to comment Share on other sites More sharing options...
Luke4efc Posted March 8, 2021 Share Posted March 8, 2021 I get the following warning message: CAUTION: Measurement of bearing clearance is not possible by normal methods and should not be attempted, as this will result in damage to the cylinder block and crankshaft. If bearing bolts have been loosened the entire cylinder block and crankshaft must be replaced. 2 Quote Link to comment Share on other sites More sharing options...
