sausageroll Posted May 10, 2010 Share Posted May 10, 2010 Hi, looking for sone more advise please, I have a new shape 2010 fiesta zetec, is there a setting where the doors will automatically lock when the car reaches a certain speed? Quote Link to comment Share on other sites More sharing options...
182_blue Posted May 10, 2010 Share Posted May 10, 2010 Its been asked before but nobody seems to know, i do know that on my old ST focus you could get the dealer to program it, but it wasnt something you could do yourself Quote Link to comment Share on other sites More sharing options...
jason4746 Posted May 10, 2010 Share Posted May 10, 2010 i know you can do it on a MK6, i had instructions and ive posted before. i also asked the same question as i have a MK7. but no luck. i asked my dealer aswell and they didnt know if it could be done. Quote Link to comment Share on other sites More sharing options...
Gazjs Posted May 10, 2010 Share Posted May 10, 2010 i know you can do it on a MK6, i had instructions and ive posted before. i also asked the same question as i have a MK7. but no luck. i asked my dealer aswell and they didnt know if it could be done. Please tell :D Quote Link to comment Share on other sites More sharing options...
Nico. Posted May 11, 2010 Share Posted May 11, 2010 must be able too.... seems abit daft if the older version could but the newer one wont, i have a few kids in the back now and again cos i take my cousins out now and again so this could do good :) Quote Link to comment Share on other sites More sharing options...
fordpartsman Posted May 11, 2010 Share Posted May 11, 2010 i have just spoken to our master technician and he says that it is more than likely done by IDS at a ford dealer Quote Link to comment Share on other sites More sharing options...
StewartM Posted May 11, 2010 Share Posted May 11, 2010 i have just spoken to our master technician and he says that it is more than likely done by IDS at a ford dealer On the BRISKODA Forum there is a lot of talk of using VCDS on a laptop to enable quite a lot of functions yourself. Is IDS or 3rd party equivalent available for Ford Owners / Enthusiasts to use as well ? If it is, I just wonder what else can be done. Stewart. Quote Link to comment Share on other sites More sharing options...
jason4746 Posted May 11, 2010 Share Posted May 11, 2010 Please tell :D 1. Turn on ignition until the dash lights come on but don't start engine! 2. Lock the door using the lever on the door handle and then unlock 3 Times 3. Turn off ignition 4. Repeat 2 but with ignition OFF 5. Turn on ignition - should hear a beep 6. Lock door again as in 2 BUT ONLY ONCE - final beep should be heard 7. Done! Quote Link to comment Share on other sites More sharing options...
irononreverse Posted May 11, 2010 Share Posted May 11, 2010 1. Turn on ignition until the dash lights come on but don't start engine! 2. Lock the door using the lever on the door handle and then unlock 3 Times 3. Turn off ignition 4. Repeat 2 but with ignition OFF 5. Turn on ignition - should hear a beep 6. Lock door again as in 2 BUT ONLY ONCE - final beep should be heard 7. Done! This isn't for the new Fiesta, we don't have a lock on the door. Quote Link to comment Share on other sites More sharing options...
jason4746 Posted May 11, 2010 Share Posted May 11, 2010 This isn't for the new Fiesta, we don't have a lock on the door. i know. this is a reply for someone asking instructions for a Mk6 Quote Link to comment Share on other sites More sharing options...
182_blue Posted May 11, 2010 Share Posted May 11, 2010 On the BRISKODA Forum there is a lot of talk of using VCDS on a laptop to enable quite a lot of functions yourself. Is IDS or 3rd party equivalent available for Ford Owners / Enthusiasts to use as well ? If it is, I just wonder what else can be done. Stewart. I have VCDS for my golf and it is very useful :-), there isnt anything like this available for fords that i have ever seen Quote Link to comment Share on other sites More sharing options...
StewartM Posted May 12, 2010 Share Posted May 12, 2010 I have VCDS for my golf and it is very useful :-), there isnt anything like this available for fords that i have ever seen Oh well, maybe some enterprising company will come up with it some day. Stewart. Quote Link to comment Share on other sites More sharing options...
Gazjs Posted May 12, 2010 Share Posted May 12, 2010 1. Turn on ignition until the dash lights come on but don't start engine! 2. Lock the door using the lever on the door handle and then unlock 3 Times 3. Turn off ignition 4. Repeat 2 but with ignition OFF 5. Turn on ignition - should hear a beep 6. Lock door again as in 2 BUT ONLY ONCE - final beep should be heard 7. Done! I done this to the exact method, although in step 6 I locked and then unlocked (Could this be the problem). The problem is it works all fine and well but when i open door to get out while engine is running or turn off car and re-start it doesn't lock. Its like its only programmed for that one ignition start Quote Link to comment Share on other sites More sharing options...
Gazjs Posted May 12, 2010 Share Posted May 12, 2010 I done this again and it works perfect this time (never unlocked just turned off engine) Thanks alot :D Quote Link to comment Share on other sites More sharing options...
wolfiecullen Posted May 18, 2010 Share Posted May 18, 2010 1. Turn on ignition until the dash lights come on but don't start engine! 2. Lock the door using the lever on the door handle and then unlock 3 Times 3. Turn off ignition 4. Repeat 2 but with ignition OFF 5. Turn on ignition - should hear a beep 6. Lock door again as in 2 BUT ONLY ONCE - final beep should be heard 7. Done! Just tried this on my Mk6 1.4 TDCi but didn't work, no beeps at all. Will have another try later. Quote Link to comment Share on other sites More sharing options...
White_ZS_TDCI Posted May 13, 2011 Share Posted May 13, 2011 did anyone manage to find out if its possible to have auto locking on the new fiesta? Quote Link to comment Share on other sites More sharing options...
rojariggs Posted January 30, 2012 Share Posted January 30, 2012 I'd be interested to know if this is possible too... Quote Link to comment Share on other sites More sharing options...
