Dil Posted March 20, 2021 Share Posted March 20, 2021 Focus MK3 autolock not working Quote Link to comment Share on other sites More sharing options...
unofix Posted March 21, 2021 Share Posted March 21, 2021 and ? 1 Quote Link to comment Share on other sites More sharing options...
Luke4efc Posted March 21, 2021 Share Posted March 21, 2021 There is no autolock? 1 Quote Link to comment Share on other sites More sharing options...
unofix Posted March 21, 2021 Share Posted March 21, 2021 Luke is correct - There is no autolock. Quote Link to comment Share on other sites More sharing options...
F0CUE Posted March 21, 2021 Share Posted March 21, 2021 It's not enabled by default you do get auto locking by speed if you need the car to auto lock when you are inside. To set this up follow the below instructions. You will need ELM327 lead https://www.amazon.co.uk/gp/product/B01F0GVBWY/ (or better a https://www.obdlink.com/ex/ lead offers more future support) Forscan software https://forscan.org/ Laptop & charger – you do not want it to die mid flash! Optional: Car battery charger – battery needs to be 100% before performing the update Make sure Forscan is installed, setup (not demo mode) and you have a license. The process Turn the vehicle ignition ON (do not start, foot off clutch) Connect to the vehicle, wait for all the modules to be read Click “configuration and programming” (6 down) Select “BCMii Central Configuration (main)” Click play (bottom left) Read and understand the warning Click “OK” Wait for the process to run, turn ignition off when requested Change “mode” from “normal” to “engineering 1” (top left) Make a backup of the current settings by clicking “Save” button (bottom toolbar) Select “Automatic locking by speed” from the list of options Click “edit selected” button (bottom toolbar) In the pop-up select “02 – Automatic Locking”, then confirm with the tick Click “Write” button (bottom toolbar) Confirm the pop-up with the tick Follow the prompt to turn the ignition back on Read and understand the warning again Click “OK” “Block(s) programmed successfully” should be displayed along with a message to cycle ignition. Do this then click “OK” Stop Forscan by clicking the stop button (bottom toolbar) Clear DTC fault codes Due to the way the update is processed and written to the car BCM you will get a number of fault codes shown. These can be cleared using Forscan Enter DTC Select Module with code At the bottom, 2nd from the left click “Reset DTC”, confirm “Yes” on pop-up Follow on screen instructions to cycle the ignition First Time Setup Go to https://forscan.org/ download & install Once installed go to settings, uncheck “demo mode” Register on the Forscan.org forum Register for the 2 month free extended license http://forscan.org/forum/extlic.php Better yet, support the development buy a full license from download page https://forscan.org/download.html Follow the steps from the forum to copy the hardware id from your installed version of Forscan into the request on the Forscan forum extended license generator One you have the license import it and start forscan for the first time, follow the instructions given for the setup of switch positions on the ELM327 lead / odblink and the ignition Forscan will look at your vehicle and detect the settings, modules and any system faults. Once setup is complete you are free to perform your chosen update / modification 1 1 Quote Link to comment Share on other sites More sharing options...
unofix Posted March 21, 2021 Share Posted March 21, 2021 Excellent information and write up. I might even give this a go on my Focus. 1 Quote Link to comment Share on other sites More sharing options...
colinmcg71 Posted March 21, 2021 Share Posted March 21, 2021 It’s just as easy to enable on the Mk4 Focus & Mk8 Fiesta, and once enabled in FORScan it just works. No need to go through the ignition on, press lock button three times, ignition off, press lock button faff that I had to do on my previous Mk3.5. This video shows it being enabled on a Mk8 Fiesta. Same process for the Mk4 Focus. 1 1 Quote Link to comment Share on other sites More sharing options...
unofix Posted March 21, 2021 Share Posted March 21, 2021 Hi all and special thanks to FoCue for his post and for Colinmcg for the youtube video. Following the information Focue posted I have used ForScan (for the very first time) and have set the Autolock to enabled on my Focus Mk4. One or two things a little tricky, (1) The car likes to switch off the ignition by itself after about 4 minutes to save the battery. Not vey good when I'm in the middle of programming. (2) Probably due to it being a Mk4 the option of BCMii has been called "BdyCM" (3) there were a possible 6 'Auto Lock' settings' so I went with the one called "Auto Lock - Vehicle". All ended well and Auto Lock works at about 6 MPH. Would love to understand what the other options were for, but I don't want to push my luck as I said earlier this is the first time I've used ForScan. 2 Quote Link to comment Share on other sites More sharing options...
Alex.S Posted March 21, 2021 Share Posted March 21, 2021 This for not getting car jacked? 😆 I’ll need to remember to avoid Durham ! 😝 1 Quote Link to comment Share on other sites More sharing options...
unofix Posted March 21, 2021 Share Posted March 21, 2021 I just need it for when I visit the relations in Glasgow 😉 2 Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted March 22, 2021 Share Posted March 22, 2021 Didn't realise it was so easy on the MK4. Have done the Mk2.5, MK3 and my Golf so would miss it now! Anything else interesting that can be enabled on a MK4 without additional hardware? Quote Link to comment Share on other sites More sharing options...
unofix Posted March 22, 2021 Share Posted March 22, 2021 Hi Tom, I did see somewhere that you can add climate controls to the Sync3 which I would quite like to try but I can't find the post now, or it may even have been something I watched on YouTube. It looked like a nice little addtion to the screen and easy to do, if anyone finds the post with the details please let me know 1 Quote Link to comment Share on other sites More sharing options...
colinmcg71 Posted March 23, 2021 Share Posted March 23, 2021 I enabled the on-screen climate controls on my Mk3.5 but ended up disabling them pretty quickly. There was a problem with the dual zone controls being reversed. Adjusting the driver's side temperature via hardware dial showed the passenger side changing and vice versa. Haven't tried enabling the climate screen on the Mk4. Yet... 1 Quote Link to comment Share on other sites More sharing options...
unofix Posted March 23, 2021 Share Posted March 23, 2021 Hi Colin, yes I found that thread last night. I saw there were problems with the driver - passenger being crossed over. I guess Ford never gave any thought to the fact that the correct side to have the steering wheel on is the RHS 😉 I wounder if they have fixed it yet for the Mk4. Possibly the Austrailian versions might have climate controls on the screen? 1 Quote Link to comment Share on other sites More sharing options...
colinmcg71 Posted March 23, 2021 Share Posted March 23, 2021 Found this on FORScan forum. I might give it a try and see if the controls are still reversed on the Mk4. Easily disabled again if so. 2 Quote Link to comment Share on other sites More sharing options...
unofix Posted March 23, 2021 Share Posted March 23, 2021 Good luck Colin, please let me know how you get on. I'm still finding my way around ForScan 1 Quote Link to comment Share on other sites More sharing options...
colinmcg71 Posted March 23, 2021 Share Posted March 23, 2021 So many climate options in the Mk4 APIM. Made the suggested changes from the FORScan forum post and nothing. No climate tab on Sync screen. Oh well, was worth a try. 1 Quote Link to comment Share on other sites More sharing options...
colinmcg71 Posted March 23, 2021 Share Posted March 23, 2021 I've found a YouTube video from Germany showing how to enable climate control on the Sync3 screen on the Mk4 (He has lots of helpful videos (with subtitles) on tweaking the Mk4 Focus - https://www.youtube.com/channel/UCsWRckMdBHabmZDwC_u53Qw). Anyhow, for Climate Control on Sync 3.4 change the following: Climate Control Type - change from Manual to Automatic Climate Domain - change from Disabled to Enabled He then pointed out that if you get incorrect distances reported while using navigation that you should change the 'Navigation Repeater Format' from Motorola to Intel or vice versa. I have yet to try this. 1 Quote Link to comment Share on other sites More sharing options...
unofix Posted March 23, 2021 Share Posted March 23, 2021 Top man Colin. Sorry to be using you as the guinea pig, but after my little victory with the Autolocking I'm still just learning. When I did the autolock on the Mk4 there were about 6 diffrent options, so no big surprise that there are a ton of options for the climate control. What version of ForScan are you using ? I seem to have the latest 2.3.39 beta, so some information that has been posted doesn't match the programme anymore. It would have been ok if I'd see and used older version first but I'll get there eventually. Thanks for you help Quote Link to comment Share on other sites More sharing options...
colinmcg71 Posted March 23, 2021 Share Posted March 23, 2021 Hi @unofix I'm using FORScan 2.3.39 too. The only option I enabled was ‘Autolock Vehicle’ I have since found more information. Enabling Autolock in the IPC as well gives you the option of turning the feature on and off from the steering wheel controls. Vehicle Settings > Locks: Before After Nice. 😎 1 Quote Link to comment Share on other sites More sharing options...
Alex.S Posted March 23, 2021 Share Posted March 23, 2021 Each to their own but I think climate control which was on some earlier sync was dropped for a reason. Not a problem having the option but I use the physical buttons anyway. For auto lock it’s a press of a button. Again if that’s what you want then it should be in the menu without having to have computer skills to set it. 1 Quote Link to comment Share on other sites More sharing options...
unofix Posted March 23, 2021 Share Posted March 23, 2021 Hi Colin you just know I'm going to have to try this don't you !! At least we are both using the same version of ForScan so I will follow your screen shots and try it tomorrow. I'll let you know what happens 😀 2 Quote Link to comment Share on other sites More sharing options...
F0CUE Posted March 23, 2021 Share Posted March 23, 2021 Well this post got interesting 😂 1 Quote Link to comment Share on other sites More sharing options...
unofix Posted March 23, 2021 Share Posted March 23, 2021 We do our best to entertain the troops 🤪 1 Quote Link to comment Share on other sites More sharing options...
DaveT70 Posted March 24, 2021 Share Posted March 24, 2021 On 3/22/2021 at 8:03 AM, TomsFocus said: Didn't realise it was so easy on the MK4. Have done the Mk2.5, MK3 and my Golf so would miss it now! Anything else interesting that can be enabled on a MK4 without additional hardware? Hi Tom, I have activated: Auto Lock Auto Re-Lock (if you get out of the car with the keys and leave it running the doors lock) Ford Performance Digital Speedometer Climate Control Functions on Sync Screen Heated Seats on Sync Screen Auto High Beam There is lots more you can do, including more of the driver's assistance pack etc 2 2 Quote Link to comment Share on other sites More sharing options...
