Baboo Posted March 21, 2021 Share Posted March 21, 2021 Hi. I have a Ford Transit 2.2 tdci 2013 in my workshop with white smoke emitting from the tail pipe, Ran up on diagnostic equipment and only fault that came up was Glow Plug No. 2 Cylinder. I changed the glow plug and fitted new injectors to all cylinders. I also changed the air mass meter cause it seems to have been getting too much air, readings were slightly off. Vehicle is still emitting white smoke and it smells like un-burnt fuel. What i did notice was someone has cut out the DPF leaving the casing. Could this be causing the smoking. I have no history for this vehicle cause it has come from several workshops and they seemed to have failed in repairing it, Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
unofix Posted March 21, 2021 Share Posted March 21, 2021 Stupid question I know but has anyone checked what fuel is in the tank ?? Its not a case that its been filled with Bio-Diesel or some other crazy fuel Quote Link to comment Share on other sites More sharing options...
Baboo Posted March 22, 2021 Author Share Posted March 22, 2021 Not a stupid question, but yes i did check the fuel in the tank because i did change the fuel filer and topped the vehicle with new diesel 50 ppm. If there is wrong fuel in the tank the vehicle will detonate on start up and the injectors will be noisy. But i will recheck the fuel again tomorrow. Under neath the vehicle near the filter I found a small pump that goes into the top of the exhaust system its a pump that delivers diesel in its raw state. Its called Exhaust-Gas after treatment fuel injector A. What is its real function and can that also cause this problem. Quote Link to comment Share on other sites More sharing options...
unofix Posted March 22, 2021 Share Posted March 22, 2021 1 hour ago, Baboo said: Exhaust-Gas after treatment fuel injector I love the sound of it - what the hell does it do ? seems a lot of people with similar problems talking about the EGR valve Quote Link to comment Share on other sites More sharing options...
Daz112 Posted June 18, 2021 Share Posted June 18, 2021 Did you find the problem. I’m having a similar problem with my custom Quote Link to comment Share on other sites More sharing options...
Christianbyron Posted January 6, 2022 Share Posted January 6, 2022 On 6/18/2021 at 11:14 AM, Daz112 said: Did you find the problem. I’m having a similar problem with my custom It's the dpf vaporiser!! That stupid thing ford created with a stupid tiny hole that clogs up !! On 6/18/2021 at 11:14 AM, Daz112 said: Did you find the problem. I’m having a similar problem with my custom Quote Link to comment Share on other sites More sharing options...
rka Posted January 24 Share Posted January 24 Hi, I have transit custom 2014, 92kw and I have problem also with the white smoke. I change dpf, also vaporiser and nothing. Same thing. If motor is cold then it okey and if warm then all starts. Can someone help, please! Quote Link to comment Share on other sites More sharing options...
