Aaron Harris Posted March 27, 2021 Share Posted March 27, 2021 Hi all, I have got a Focus MK3 ST and the front breaks need replacing in the near future. Wanted to know what non standard Ford ones people would recommend. thanks Aaron Quote Link to comment Share on other sites More sharing options...
Luke4efc Posted March 27, 2021 Share Posted March 27, 2021 If you're having no trouble with your current disc/pad setup then I'd honestly just stick with genuine Ford all round. If you really want an upgrade then the EBC yellow stuff are good for fast road use. Quote Link to comment Share on other sites More sharing options...
StephenFord Posted March 27, 2021 Share Posted March 27, 2021 22 minutes ago, Luke4efc said: If you're having no trouble with your current disc/pad setup then I'd honestly just stick with genuine Ford all round. If you really want an upgrade then the EBC yellow stuff are good for fast road use. I would have to agree, I spent 10 years looking for that elusive brake upgrade to my Celica GT4, near the end, I just reverted to Toyota standard fitment, and the performance was excellent! Quote Link to comment Share on other sites More sharing options...
Aaron Harris Posted March 27, 2021 Author Share Posted March 27, 2021 1 hour ago, Luke4efc said: If you're having no trouble with your current disc/pad setup then I'd honestly just stick with genuine Ford all round. If you really want an upgrade then the EBC yellow stuff are good for fast road use. Ford ones leave so much break dust I have heard that after market ones are a lot better and less break dust. Quote Link to comment Share on other sites More sharing options...
Jim H Posted March 27, 2021 Share Posted March 27, 2021 I have used EBC discs and pads on all of our cars with no problems. From an old Metro to an Impreza. The pads are kinder to discs and supposed to produce less dust than others. If you don't go for EBC, then certainly buy well known names, Mintex, Ferodo, Pagid, Brembo, etc. Quote Link to comment Share on other sites More sharing options...
VFR800 Posted March 28, 2021 Share Posted March 28, 2021 12 hours ago, Aaron Harris said: Ford ones leave so much break dust I have heard that after market ones are a lot better and less break dust. Having pad dust is better than them just eating away at the discs. EBC are always a well-known and reliable option, sometimes it's just better sticking with OEM. https://ebcbrakes.com/products/brake-pads/ Next we start on the "brake grease or no break grease debate!!" 1 Quote Link to comment Share on other sites More sharing options...
F0CUE Posted March 28, 2021 Share Posted March 28, 2021 8 hours ago, VFR800 said: Next we start on the "brake grease or no break grease debate!!" Yes ceratec grease unless the pads come with special shims or you like squeaks 🐭 2 Quote Link to comment Share on other sites More sharing options...
Jim H Posted March 28, 2021 Share Posted March 28, 2021 I have always used copper slip on the back of pads and contact points. Never had any problems, however I have read you shouldn't use metallic grease, and use Ceratec instead. Not sure what to use on slider pins though. Quote Link to comment Share on other sites More sharing options...
F0CUE Posted March 28, 2021 Share Posted March 28, 2021 28 minutes ago, Jim H said: I have always used copper slip on the back of pads and contact points. Never had any problems, however I have read you shouldn't use metallic grease, and use Ceratec instead. Not sure what to use on slider pins though. Copper slip conducts heat so being on the back of brake pads is not the best idea. The best grease for slider pins would be Dielectric Grease/Silicone Paste/Waterproof Marine Grease. Quote Link to comment Share on other sites More sharing options...
Aaron Harris Posted March 29, 2021 Author Share Posted March 29, 2021 Another thought. When should I change the break discs? is it right that the front should measure 24mm when new and 22mm when they need changing and rear 12.5mm new and 10.5mm need changing. Ford have only highlighted that the pads need doing in and not mentioned the discs. Quote Link to comment Share on other sites More sharing options...
Luke4efc Posted March 29, 2021 Share Posted March 29, 2021 5 hours ago, Aaron Harris said: Another thought. When should I change the break discs? is it right that the front should measure 24mm when new and 22mm when they need changing and rear 12.5mm new and 10.5mm need changing. Ford have only highlighted that the pads need doing in and not mentioned the discs. Sounds about the right tolerances. Most people just change them when there's a lip. If you're doing it yourself then I tend to have a look at the disc and see how bad the lip is around the edge and check for any grooves. If they're fine I'll just buy pads. If you're sending it to a garage then you may aswell get new discs too. The cost of them will be nowhere near the labour cost. 1 1 Quote Link to comment Share on other sites More sharing options...
Aaron Harris Posted March 30, 2021 Author Share Posted March 30, 2021 14 hours ago, Luke4efc said: Sounds about the right tolerances. Most people just change them when there's a lip. If you're doing it yourself then I tend to have a look at the disc and see how bad the lip is around the edge and check for any grooves. If they're fine I'll just buy pads. If you're sending it to a garage then you may aswell get new discs too. The cost of them will be nowhere near the labour cost. I am going to do it my self so I will have a look before hand. Thanks Quote Link to comment Share on other sites More sharing options...
