LewisTneary Posted March 27, 2021 Share Posted March 27, 2021 Hi all. Recently purchased a Fiesta Titanium 67 plate. It has automatic lights, which I previously didn’t have. When the auto lights system is on and it’s bright, the headlights aswell as the day running lights also come on (green light appears on the dash) I assume this isn’t right. Any ideas to change it so only the day lights come on and when the sun goes down the headlights come on? Thank you. Quote Link to comment Share on other sites More sharing options...
unofix Posted March 27, 2021 Share Posted March 27, 2021 Hi Lewis, can you post a picture of your light switch with it set to auto. I would just like to confirm which system you have Quote Link to comment Share on other sites More sharing options...
Jim H Posted March 27, 2021 Share Posted March 27, 2021 Hello and welcome to the forum. Auto lights should turn on either when it gets dark or when the wipers are on for a while. If they are on (green light showing) in bright sunlight, then there is a fault with them, possibly the sensor on the windscreen. 1 Quote Link to comment Share on other sites More sharing options...
Jim H Posted March 27, 2021 Share Posted March 27, 2021 38 minutes ago, unofix said: Hi Lewis, can you post a picture of your light switch with it set to auto. I would just like to confirm which system you have Being a 2018, 67 plate it will be most likely to be a mk8 Fiesta The symbol with an A in it is Auto lights, To turn them off (drl) rotate to 'O' position. However the car defaults back to Auto whenever you get back into the again. Quote Link to comment Share on other sites More sharing options...
Tiexen Posted March 28, 2021 Share Posted March 28, 2021 I had a Mk 7.5 and the auto lights used to come on if it was really sunny, my Mk8 doesn't do it. Quote Link to comment Share on other sites More sharing options...
Dave j h Posted July 14, 2022 Share Posted July 14, 2022 Hi I’ve just bought a fiesta st. I want to know if both sidelights should come on when lights are on automatic, as one of them does not Quote Link to comment Share on other sites More sharing options...
unofix Posted July 14, 2022 Share Posted July 14, 2022 With the ignition OFF and the light switch set to parking lights only (used to be called side lights) then both small white lamps at the front and both red rear lights should be illuminated. If when you do this check, one of the front white lamps is not on then you need to replace it. Quote Link to comment Share on other sites More sharing options...
