Zananamanon Posted April 8, 2021 Share Posted April 8, 2021 Hi all, I have a 2015 mondeo, and I have just started having intermittent issues. It will flash up with esc service required on the dash and the abs and tc lights will come on. It will say hill start assist unavailable and park assist stops working. Sometimes the lights go off after a minute or so, other times they stay on until I turn off and on the ignition. Car seems to still drive fine with the lights on. I have just got forscan with a modified cable so am able to read any dtc codes, but unfortunately I'm not exactly sure where to start to diagnose the issue. Have searched online and have found it could just be an abs sensor that's need replacing. Is it possible to use forscan to narrow down exactly where the issue lies?? Any help would be much appreciated. Quote Link to comment Share on other sites More sharing options...
MasterTechTip Posted April 8, 2021 Share Posted April 8, 2021 Wheel speed sensors are pretty common on these Mondeo's, usually it's 1 of the front ones. I haven't used Forscan but it should tell you what sensor it is (i.e. left front, right front, etc.) Quote Link to comment Share on other sites More sharing options...
Tizer Posted April 8, 2021 Share Posted April 8, 2021 What fault codes did you get?. You should be able to get Live readings from each of the wheel sensors if you go into Dashboard and search for the relevant PID's. They will probably be in the ABS Module, just scroll through them. I'm sure there is also an all modules PID search function to make life easier. Once you have them on your Dashboard press Play and take the car for a run. If the fault occurs and it is one of the sensors it will be obvious. Quote Link to comment Share on other sites More sharing options...
Zananamanon Posted April 8, 2021 Author Share Posted April 8, 2021 Thank you for the replies. I had about 25-30 codes when I first ran forscan yesterday. I have reset them to see what codes return, but sods law the esc warning never appeared today. Is it safe to run forscan while driving as I only have the pc software, I guess as long as I'm not watching the lappy while I drive I should be safe. I will be running it again tomorrow as I plan to take it on a good drive as I think it needs a dpf regen. The car used to be a taxi so has high milage and a lot of short stop start journeys, but I got a good saving on the average price I paid. Once I have scanned again tomorrow I will post back with the codes that reappear. Quote Link to comment Share on other sites More sharing options...
Tizer Posted April 9, 2021 Share Posted April 9, 2021 Live Monitoring should not do the car any harm but it is awkward with a wired adaptor and a Laptop. 1 Quote Link to comment Share on other sites More sharing options...
Zananamanon Posted April 9, 2021 Author Share Posted April 9, 2021 the esc error came on on my way to work this morning, got home and run a scan and have the following codes. Looks like the front left abs sensor problem, does it mean it needs replacing though?? ===FCIM DTC None=== Successful DTC reading, no error codes found Module: Front Controls Interface Module ===END FCIM DTC None=== ===ABS DTC C0031:15-28=== Code: C0031 - Left Front Wheel Speed Sensor Additional Fault Symptom: - Circuit Short To battery Or Open Status: - Previously Set DTC - Not Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Antilock braking system Freeze Frame : -GLOBTIM: 193310546 s - Global real time -TOTDIST: 262810.0 km - Total Distance -MAINECUV: 14.50 V - Main ECU voltage supply -OUTTMP: 7 °C - External Temperature From Sensor -POWER_MODE: Running - Power Mode Status -ABS: Active - ABS -AYC: Inactive - AYC -BTCS: Inactive - BTCS -201D -HDC: Inactive - HDC -RSC: Inactive - RSC -BTC: Inactive - BTC -VAC_BST_ST: Inactive - Active Vacuum Booster State -BST_REL_SW: Inactive - Booster Release Switch State -HYD_PMP_ST: Inactive - Hydraulic Pump State -VPWR_ABS: 14.60 V - Module supply voltage -VSS: 24.0 km/h - Vehicle Speed ===END ABS DTC C0031:15-28=== ===ABS DTC C0051:67-68=== Code: C0051 - Steering Wheel Position Sensor Additional Fault Symptom: - Signal Incorrect After Event Status: - Previously Set DTC - Not Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC - Test not complete Module: Antilock braking system Freeze Frame : -GLOBTIM: 193310586 s - Global real time -TOTDIST: 262810.0 km - Total Distance -MAINECUV: 14.50 V - Main ECU voltage supply -OUTTMP: 7 °C - External Temperature From Sensor -POWER_MODE: Running - Power Mode Status -ABS: Inactive - ABS -AYC: Inactive - AYC -BTCS: Inactive - BTCS -201D -HDC: Inactive - HDC -RSC: Inactive - RSC -BTC: Inactive - BTC -VAC_BST_ST: Inactive - Active Vacuum Booster State -BST_REL_SW: Inactive - Booster Release Switch State -HYD_PMP_ST: Inactive - Hydraulic Pump State -VPWR_ABS: 14.70 V - Module supply voltage -VSS: 0.0 km/h - Vehicle Speed ===END ABS DTC C0051:67-68=== ===RTM DTC None=== Successful DTC reading, no error codes found Module: Radio Transceiver Module ===END RTM DTC None=== ===PDM DTC None=== Successful DTC reading, no error codes found Module: Passengers Door Control Unit ===END PDM DTC None=== ===DDM DTC None=== Successful DTC reading, no error codes found Module: Drivers Door Module ===END DDM DTC None=== ===RCM DTC None=== Successful DTC reading, no error codes found Module: Restraint Control Module ===END RCM DTC None=== ===PSCM DTC U0415:00-08=== Code: U0415 - Invalid Data Received from Anti-Lock Brake System (ABS) Control Module A Status: - Previously Set DTC - Not Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Power Steering Control Module Freeze Frame : -STEER_FEEL: Comfort - Steering Personalization Status -SW_ANGLE: 0.00 ° - Steering Wheel Angle -ODOMETER: 262810.0 km - Total Distance -MOD_SUP_V: 14.60 V - Module Supply Voltage -PSCM_INT_TEMP: 14 °C - PSCM Internal Temperature -EPAS_MOTOR_CUR: 0.00 A - EPAS Motor Current -VSS: 22.0 km/h - Vehicle Speed ===END PSCM DTC U0415:00-08=== ===ACM DTC None=== Successful DTC reading, no error codes found Module: Audio Control Module ===END ACM DTC None=== ===SCCM DTC None=== Successful DTC reading, no error codes found Module: Steering Column Control Module ===END SCCM DTC None=== ===IPC DTC U0230:00-0A=== Code: U0230 - Lost Communication With Rear Gate Module Status: - DTC Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Instrument Panel Control Module ===END IPC DTC U0230:00-0A=== ===GWM DTC None=== Successful DTC reading, no error codes found Module: Gateway Module A ===END GWM DTC None=== ===GPSM DTC None=== Successful DTC reading, no error codes found Module: Global Positioning System Module ===END GPSM DTC None=== ===PCM DTC None=== Successful DTC reading, no error codes found Module: Powertrain Control Module ===END PCM DTC None=== ===OBDII DTC None=== Successful DTC reading, no error codes found Module: On Board Diagnostic II ===END OBDII DTC None=== ===APIM DTC B1215:00-28=== Code: B1215 - External Memory Card Status: - Previously Set DTC - Not Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Accessory Protocol Interface Module ===END APIM DTC B1215:00-28=== ===DCDC DTC None=== Successful DTC reading, no error codes found Module: DC to DC Converter Control Module ===END DCDC DTC None=== ===PAM DTC U0415:00-28=== Code: U0415 - Invalid Data Received from Anti-Lock Brake System (ABS) Control Module A Status: - Previously Set DTC - Not Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Parking Aid Module ===END PAM DTC U0415:00-28=== ===PAM DTC U0557:00-28=== Code: U0557 - Invalid Data Received From Front Controls Interface Module A Status: - Previously Set DTC - Not Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Parking Aid Module ===END PAM DTC U0557:00-28=== ===BCMii DTC None=== Successful DTC reading, no error codes found Module: Body Control Module ===END BCMii DTC None=== Quote Link to comment Share on other sites More sharing options...
Tizer Posted April 9, 2021 Share Posted April 9, 2021 Looks more like a wiring fault. I would do a careful inspection of the connection and as much wiring as is practicable first before doing anything else. Quote Link to comment Share on other sites More sharing options...
Zananamanon Posted April 10, 2021 Author Share Posted April 10, 2021 A wiring fault from the sensor or somewhere else ? Quote Link to comment Share on other sites More sharing options...
Grantbp Posted May 17, 2021 Share Posted May 17, 2021 Hi, I have the exact same errors codes U0415,C0051 and C0031 and the exact same symptoms only mine is very intermittent and lights always go off after 30 seconds. I'm thinking a wiring issue which could be hard to find or a fault with the abs module. Just wondering did you find a resolution, thanks Quote Link to comment Share on other sites More sharing options...
Zananamanon Posted May 22, 2021 Author Share Posted May 22, 2021 I am still having them pop up now and again, last time was yesterday but they went off on their own after a short while. I believe its an abs sensor issue on mine from when I have read the codes with forscan, I believe it's a common issue. So I brought a new one and just need to fit it to see if it resolves the issue. The problem I have at the moment is I can't get the wheels off as the locking nut key is rounded off 🤨 Quote Link to comment Share on other sites More sharing options...
RAGNAR Posted September 26, 2021 Share Posted September 26, 2021 Hi there I'm having the same issues with my 15 plate mondeo is it expensive to put right Quote Link to comment Share on other sites More sharing options...
Tommyh Posted January 13, 2022 Share Posted January 13, 2022 Hi there. I have recently been having the same problem but with a twist as my 1.5 tdci engine seems to misfire and then the ESC lights up saying service needed and Abs with traction control lights displaying also. Any one have any ideas. Quote Link to comment Share on other sites More sharing options...
unofix Posted January 13, 2022 Share Posted January 13, 2022 16 minutes ago, Tommyh said: ESC lights up saying service needed and Abs with traction control lights displaying also. Any one have any ideas. It's not something to guess at otherwise it gets very expensive very quickly. Get a laptop with the software FORScan and read the DTC's. FORScan: https://forscan.org/download.html Connecting lead: https://tunnelrat-electronics.fwscart.com/USB_Modified_with_switch_ELM327/p4541936_17045457.aspx Quote Link to comment Share on other sites More sharing options...
Tommyh Posted February 2, 2022 Share Posted February 2, 2022 Thanks unofix will give it a go. 1 Quote Link to comment Share on other sites More sharing options...
ChicNic Posted June 19, 2022 Share Posted June 19, 2022 Did anyone find out the issue for this as my Mondeo has started this same issue with the ESC light still drives ok Quote Link to comment Share on other sites More sharing options...
unofix Posted June 19, 2022 Share Posted June 19, 2022 Same problem = Same answer On 1/13/2022 at 3:16 PM, unofix said: It's not something to guess at otherwise it gets very expensive very quickly. Get a laptop with the software FORScan and read the DTC's. FORScan: https://forscan.org/download.html Connecting lead: https://tunnelrat-electronics.fwscart.com/USB_Modified_with_switch_ELM327/p4541936_17045457.aspx Quote Link to comment Share on other sites More sharing options...
col4519 Posted December 3, 2022 Share Posted December 3, 2022 I have the same issue on my 2016. 1 Quote Link to comment Share on other sites More sharing options...
Relwog Posted March 14 Share Posted March 14 I have a 2021 Vignale diesel estate and, for the past few weeks, I’ve been getting random warning messages - traction control, cross traffic alert, hill start assist, adaptive headlights, engine warning light (amber), abs. took it to a dealer (still under warranty and has only done 18,000 miles) but, by the time I could get it booked in, all the warning lights had gone out. They checked all of the error messages (thirty odd!) but couldn’t pinpoint a specific problem. tonight, they’ve all started again and this time the car wouldn’t change gear (8 speed auto) and the dev clock kept dropping out. Has anyone any ideas - this is driving me mad! Quote Link to comment Share on other sites More sharing options...
unofix Posted March 15 Share Posted March 15 Yes it's a very simple and quite common problem. Your car battery is very low on charge. It needs to be correctly charged using a smart battery charger. The battery should be charged while still connected to the vehicle. Battery charger positive lead direct to the battery terminal and the negative charger lead connected to the chassis main earth point NOT the battery. Will take a minimum of 12 hours, but more likely 24 hours to get the SOC back to 80% or better. Quote Link to comment Share on other sites More sharing options...
G.M Posted Tuesday at 11:47 AM Share Posted Tuesday at 11:47 AM Hello unofix. I have tried charging my 2016 mondeo 1.5 diesel with smart charger but i just connected positive and negative to the battery, why do you say connect the negative to the chasis? I am a novice so sorry if this is a silly question. Thanks Quote Link to comment Share on other sites More sharing options...
