John6177 Posted April 12, 2021 Author Share Posted April 12, 2021 No problems will let you all know what happens next John Baylis Quote Link to comment Share on other sites More sharing options...
John6177 Posted April 16, 2021 Author Share Posted April 16, 2021 Hi, Got an update on the fiesta fan issue, plugged in my scanner, which has not brought up any faults, changed the relay, and finally swapped over the fan. When I plugged it in, I removed the air-con relay and put it back in again, the fan has not come on since, I have started it many times and even used it. So fingers crossed it may have been solved, may have been a combination of problems. Thanks for all your thoughts and ideas which have guided me through this. John 1 Quote Link to comment Share on other sites More sharing options...
unofix Posted April 16, 2021 Share Posted April 16, 2021 Hi John, glad to know you have got it sorted 🙂 Quote Link to comment Share on other sites More sharing options...
John6177 Posted April 16, 2021 Author Share Posted April 16, 2021 No Probs👍 Quote Link to comment Share on other sites More sharing options...
John6177 Posted April 26, 2021 Author Share Posted April 26, 2021 Hi All, Just an update on the fan Issue, annoyingly enough my car fan is back on all the time which sometimes turns off, then back on again., especially from cold, so far I have replaced my electric cooling fan as I did discover the plug was broken, Swapped the cooling fan relay several times and made no difference, coolant temperature sensor has been done. and still does it. All that's left is fixing the air-con which seems to have several pipes mangled under the engine and makes a clicking sound all the time and to replace the thermostat, which I am not sure may be causing Issues?. What does everyone think of other potential factors. Thanks John Quote Link to comment Share on other sites More sharing options...
Dan62 Posted April 26, 2021 Share Posted April 26, 2021 Is the ventilation control turned to the windscreen only position, if so turn it away to a different position. Quote Link to comment Share on other sites More sharing options...
John6177 Posted April 27, 2021 Author Share Posted April 27, 2021 Does this make a difference. I will check this and see what happens. John Quote Link to comment Share on other sites More sharing options...
Dan62 Posted April 27, 2021 Share Posted April 27, 2021 On some models under certain conditions the heater control module can turn the AC on. It was just a thought, I'm sure the fan issue is AC related especially since you said its making a clicking noise. The only other thought apart from fixing the AC is removing the WOT relay from the relay box. Quote Link to comment Share on other sites More sharing options...
John6177 Posted April 27, 2021 Author Share Posted April 27, 2021 I have checked and it was on the windscreen setting, will test later and let you know how I get on. Just a thought do you think it could be anything to do with the thermostat? All thoughts appreciated. Thanks John Baylis Quote Link to comment Share on other sites More sharing options...
John6177 Posted April 27, 2021 Author Share Posted April 27, 2021 Hi, Tested the car and fan does still come on and then keep on turning off. Just thought you should know. John Quote Link to comment Share on other sites More sharing options...
