danialhunt Posted April 12, 2021 Share Posted April 12, 2021 Where is the glow plug relay on the 06 S-max 2.0 Tdci. its showing as a fault on a Snap-on scanner, along with the plugs themselves which have been changed and MaF Sensor which has been changed also. all i need is to find and replace the Relay/control unit for the Glow plugs and can not find it. Help please. Quote Link to comment Share on other sites More sharing options...
danialhunt Posted April 14, 2021 Author Share Posted April 14, 2021 No one know Quote Link to comment Share on other sites More sharing options...
unofix Posted April 15, 2021 Share Posted April 15, 2021 The S-max glow plug relay is located towards the rear of the engine, beneath the airbox and in front of the gearbox. 1 Quote Link to comment Share on other sites More sharing options...
unofix Posted April 17, 2021 Share Posted April 17, 2021 Hi Dan, I will take a look and see if I can find some pictures that might help. Give me a couple of hours Quote Link to comment Share on other sites More sharing options...
unofix Posted April 17, 2021 Share Posted April 17, 2021 Hi Dan, have you seen the post in the S-Max forum called Glow plug rely Search for that - yes it is spelt wrong. Posted August 26 2020 by James Shepherd. Follow the thread it might well help. Quote Link to comment Share on other sites More sharing options...
danialhunt Posted April 18, 2021 Author Share Posted April 18, 2021 On 4/15/2021 at 9:39 AM, unofix said: Quote Link to comment Share on other sites More sharing options...
danialhunt Posted April 18, 2021 Author Share Posted April 18, 2021 So after digging I still can’t see it. Are any of these built in to the PCM? Quote Link to comment Share on other sites More sharing options...
Tdci-Peter Posted April 18, 2021 Share Posted April 18, 2021 57 minutes ago, danialhunt said: Are any of these built in to the PCM? Very unlikley to be in the PCM, More likely in the engine bay fuse box. Have you checked out this info, I am assuming a Mk3 Mondeo will be very similar, though the Mk4 came in about 2007. Quote Link to comment Share on other sites More sharing options...
danialhunt Posted April 18, 2021 Author Share Posted April 18, 2021 22 minutes ago, Tdci-Peter said: Very unlikley to be in the PCM, More likely in the engine bay fuse box. Have you checked out this info, I am assuming a Mk3 Mondeo will be very similar, though the Mk4 came in about 2007. Yeah all relays in the fuse box have been checked. I can’t find the glow plug control module so I’m thinking it’s controlled by the PCM Quote Link to comment Share on other sites More sharing options...
unofix Posted April 19, 2021 Share Posted April 19, 2021 Hello Dan, there are two fuses, a relay and a control module for the glow plugs on your S-max so it would seem acording to this YouTube video: F2 - 5Amp F4 - 60Amp Quote Link to comment Share on other sites More sharing options...
unofix Posted April 19, 2021 Share Posted April 19, 2021 Dan, I can't quite make it out for sure but it looks like I can see the relay control on one of your photos (see below) Quote Link to comment Share on other sites More sharing options...
danialhunt Posted April 19, 2021 Author Share Posted April 19, 2021 2 hours ago, unofix said: Hello Dan, there are two fuses, a relay and a control module for the glow plugs on your S-max so it would seem acording to this YouTube video: F2 - 5Amp F4 - 60Amp I have found the fuses and the relay but can not find the control module. Quote Link to comment Share on other sites More sharing options...
unofix Posted April 19, 2021 Share Posted April 19, 2021 Hi Dan, was the relay the one I posted with the Red arrow on the photo? The relay you found was it like the one in my last post? Quote Link to comment Share on other sites More sharing options...
danialhunt Posted April 22, 2021 Author Share Posted April 22, 2021 On 4/19/2021 at 12:20 PM, unofix said: Dan, I can't quite make it out for sure but it looks like I can see the relay control on one of your photos (see below) I’ll get a better photo of the area Quote Link to comment Share on other sites More sharing options...
danialhunt Posted April 22, 2021 Author Share Posted April 22, 2021 Quote Link to comment Share on other sites More sharing options...
Moises Posted April 2, 2022 Share Posted April 2, 2022 Hi all, about this relê, did you find it? im also looking for that Quote Link to comment Share on other sites More sharing options...
