Mk 2.5 1.6 tdi body
Hi I was looking to get a front splitter side skirts and maybe a rear disfussor for my 5 door tdi zetec is the body the same on them as the st or is there anywhere I can get a kit the seller on ebay said that it won't fit
The seller is correct, they won't fit. The side skirts are like an extension ontop of an extension which you don't have.
The ST also has dual exhaust so you'll be left with a gaping hole at both sides as your current pea shooter won't line up with either cut out.
Sound lad id get over the rear it was the sides and the front. Il keep looking for something
How does that work?  Are the ST skirts different to the Zetec S skirts?
The ST and zetec-S share the same size skirts and spoiler, but the regular zetec is different. So to fit ebay side skirts you'd have to fit the ST side skirts, and then add the ebay ones ontop of those (I'm assuming he's referring to the thin black ones that screw in from underneath).
Ah I see, misunderstood the first post. :smile:
Thanks so much il try and get both so should be nice when it's done. Is the front lip ok to buy surely there the same?
No. The Zetec-S has an extra skirt around the bottom, and the ST bumper is completely different.
Damn looks like standard look so
Didn't mean to double quote is there anything I can do to the zetec or is it standard only
