Steve Hassall Posted April 15, 2021 Share Posted April 15, 2021 Stupid question time,if there's no instrument lights at all on the dashboard is it a flat battery? Also the key fob wouldn't open the door I had to open it via the key lock Quote Link to comment Share on other sites More sharing options...
Neb_engineer Posted April 15, 2021 Share Posted April 15, 2021 that sounds like either a flat battery or the master battery fuse has blown Quote Link to comment Share on other sites More sharing options...
Waggy Posted April 15, 2021 Share Posted April 15, 2021 4 minutes ago, Neb_engineer said: that sounds like either a flat battery or the master battery fuse has blown Or the comms has gone ***** up. I'm assuming you don't have a multimeter to check battery volts? Quick check - disconnect battery for 10 mins and see if it all comes back to life when reconnected. If not, most probably duff battery. 1 Quote Link to comment Share on other sites More sharing options...
Steve Hassall Posted April 16, 2021 Author Share Posted April 16, 2021 Thanks for advise guys...... It was the battery 2 Quote Link to comment Share on other sites More sharing options...
