Power Fold Mirrors MK 2.5
I have managed to get a hold of a set of power folding mirrors and I am wanting to retrofit fit them to my Focus mk2.5 Titanium. I have the global window closing with the key fob so I believe the modules are correct.
The new wing mirrors plug in and work fine for indicator and mirror adjustment and I am aware that the power folding needs to be enabled in software.
I don't have the door switch to make the mirrors fold / unfold but I don't particularly want the button I am more interested in getting them to fold / unfold with the key fob.
Also I have noticed that the connector for the power fold mirrors have two extra pins populated but my connector has no pins or wires in it. I assume the extra pins are for the power folding mirrors and / or the puddle lights.
Any help on this would be greatly appreciated 🙂
Hello Steve and welcome to the Ford Owners Club.
There is already a thread running on the subject of power fold door mirrors. I think you will find its a lot harder than you expect to get them working.
Take a look at this:
https://www.fordownersclub.com/forums/topic/125471-issues-with-upgrading-to-powerfolding-mirrors-from-basic-door-mk3/?tab=comments#comment-877241
Thanks for that, however that is for the MK3, I already have the correct door modules and global closing feature.
You should be able to enable powerfold in ELMConfig with a modified ELM cable.  (£20 on Tunnelrat site)
But even factory fitted they never folded on the key on the Mk2.5.  You need the much more expensive UCDS cable/software to enable that.
You will need a loom adjustment but I don't know exactly how much.
Thanks Tom 🙂
I heard a user called Tezza has the UCDS cable and is able to make them fold / unfold with the key fob. I think he is quite local to me maybe Sheffield area.
I assume I will have to run some wires from the module to the mirror (to populate the two extra pins) to make them work and I know it is possible.
5 minutes ago, stevejwalford said:
Thanks Tom 🙂
It may need more wiring than just to the module, I really don't know how much is already there I'm afraid.
If you can reach Tezza, he's definitely the guy to ask.  Haven't seen him on here for a while though!
Would some pictures of the drivers side module / door / wiring help you to see what needs adding?
