Gear issues!
Hi all, I'm new to the club and have started having problems with my gears.
I have a Focus MK2.5 1.6 and this morning I've found that once I press the clutch while the engine is running, gears do not lock in ( I can release the clutch while I'm trying to get into gear and it stays sat at the biting point. Should point out, reverse is the only gear that functions as normal.
I'm in the process of topping up the brake/clutch fluid with hopes it helps, otherwise, any ideas on what could be causing this issue?
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
