Alexnash93 Posted April 22, 2021 Share Posted April 22, 2021 Hi all, I'm new to the club and have started having problems with my gears. I have a Focus MK2.5 1.6 and this morning I've found that once I press the clutch while the engine is running, gears do not lock in ( I can release the clutch while I'm trying to get into gear and it stays sat at the biting point. Should point out, reverse is the only gear that functions as normal. I'm in the process of topping up the brake/clutch fluid with hopes it helps, otherwise, any ideas on what could be causing this issue? Quote Link to comment Share on other sites More sharing options...
