Dave2016 Posted April 23, 2021 Share Posted April 23, 2021 FORD TRANSIT CUSTOM 2016 Hi, when i press the power button on the radio all i get on screen is FORD AUDIO and a white cog symbol to the bottom left hand side. Recently been in for a service and the mechanic said itll need a new radio unit. Sourced and fitted one today and same problem occurs. Can anybody help. Thanks Quote Link to comment Share on other sites More sharing options...
Frembrit Posted April 23, 2021 Share Posted April 23, 2021 Might be worth checking/asking the Custom Owners Group on Facebook if you can...https://www.facebook.com/groups/998535056938838 be prepared for stupid answers/banter though, but usually someone will provide a sensible reply. Quote Link to comment Share on other sites More sharing options...
iantt Posted April 23, 2021 Share Posted April 23, 2021 What radio unit does it have ? Sync2 screen ? Quote Link to comment Share on other sites More sharing options...
Dave2016 Posted April 24, 2021 Author Share Posted April 24, 2021 Sorry for the delay. Its got the separate screen on the dash if that helps. Think its the sync2 Quote Link to comment Share on other sites More sharing options...
Dave2016 Posted April 24, 2021 Author Share Posted April 24, 2021 19 hours ago, iantt said: What radio unit does it have ? Sync2 screen ? Sorry for the delay. Its got the separate screen on the dash if that helps. Think its the sync2 Quote Link to comment Share on other sites More sharing options...
iantt Posted April 24, 2021 Share Posted April 24, 2021 Like this? If so what part of the radio have you replaced? Quote Link to comment Share on other sites More sharing options...
Dave2016 Posted April 25, 2021 Author Share Posted April 25, 2021 8 hours ago, iantt said: Like this? If so what part of the radio have you replaced? This is what i changed. After removing radio theres the cd box behind, is it worth replacing that? Quote Link to comment Share on other sites More sharing options...
unofix Posted April 25, 2021 Share Posted April 25, 2021 Hello Dave, I think that all you have changed is the front panel control. The CD box as you call it is actually the Radio and the brains of the system. You will need to replace that unit, but I'm not sure if you will need the security code for the replacment 2 Quote Link to comment Share on other sites More sharing options...
Dave2016 Posted April 25, 2021 Author Share Posted April 25, 2021 13 minutes ago, unofix said: Hello Dave, I think that all you have changed is the front panel control. The CD box as you call it is actually the Radio and the brains of the system. You will need to replace that unit, but I'm not sure if you will need the security code for the replacment Ok thanks, I'll get one ordered. Hopefully thatll sort the problem. 👍 Quote Link to comment Share on other sites More sharing options...
iantt Posted April 25, 2021 Share Posted April 25, 2021 So you replaced basically the buttons. The cd bit is indeed the ACM audio control module. But also the screen can cause nothing to work . Pain in the ***** with separate bits to a radio. So it's guessing time. ACM or screen or both. And for reference you have sync 1 or 1.1. 1 Quote Link to comment Share on other sites More sharing options...
Dave2016 Posted April 25, 2021 Author Share Posted April 25, 2021 26 minutes ago, iantt said: So you replaced basically the buttons. The cd bit is indeed the ACM audio control module. But also the screen can cause nothing to work . Pain in the ***** with separate bits to a radio. So it's guessing time. ACM or screen or both. And for reference you have sync 1 or 1.1. Lol yes it would seem i just changed the buttons, i havent got a clue when it comes to things like this. Ok thanks, I'll probably try the ACM first. Quote Link to comment Share on other sites More sharing options...
Bward2 Posted February 21 Share Posted February 21 Hi, did you get your problem solved with your radio? I have the same problem Quote Link to comment Share on other sites More sharing options...
