Forscan Focus MK3
Aaron Harris
 Share
Hi all,
I have bought a OBD cable so I can use Forscan.
I have enabled auto lock I was wondering if there’s any other things I can do with it? I have Sync 2 system.
Aaron
Link to comment
1 hour ago, Aaron Harris said:
Herkese selam,
Forscan'i kullanabilmek için bir OBD kablosu satın aldım.
Otomatik kilidi etkinleştirdim Bununla yapabileceğim başka bir şey olup olmadığını merak ediyordum. Sync 2 sistemim var.
Teşekkürler
Harun
Hello my friend. Yes what is the model year and package of the vehicle? Which features are unlocked according to him, I can help you.
Link to comment
Hi.
I have a MK3 facelift 2016. I believe I have sync 2.
Aaron
Link to comment
Not a lot really, just go through the configuration & programming section (not asbuilt) and see what you can turn on.
From memory on my 2016 MK3.5, not a lot other than drive away locking.
Maybe you can turn on Fogs as DRLs but that's about it I think.
Make sure you back up the module before you make changes.
If you mess something up just re-load your standard config
Link to comment
Hi Aaron, you should be able to turn on Global opening and Global closing if you don't already have that - All windows down / All windows up by holding down the button on your keyfob for 3 seconds.
  • Like 1
Link to comment
Already got that one 👍🏻
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
