big rab Posted April 25, 2021 Share Posted April 25, 2021 sidelights front and back not working bulbs and fuses ok is there another fuse box. thanks Quote Link to comment Share on other sites More sharing options...
Luke4efc Posted April 25, 2021 Share Posted April 25, 2021 There is a fusebox in the engine bay and another in the cab, but the don't go through both fuseboxes if that's what you mean? Obviously you must already know where the relevant fuse location is because you've said they're ok. Quote Link to comment Share on other sites More sharing options...
big rab Posted April 25, 2021 Author Share Posted April 25, 2021 Yes checked fuses behind glovebox Quote Link to comment Share on other sites More sharing options...
DaveT70 Posted April 26, 2021 Share Posted April 26, 2021 Faulty Switch? Faulty BCM? Check all connections Quote Link to comment Share on other sites More sharing options...
Dan62 Posted April 26, 2021 Share Posted April 26, 2021 17 hours ago, big rab said: sidelights front and back not working bulbs and fuses ok is there another fuse box. thanks Without the key in do the lamps work when you turn the switch to the parking lamp position? Quote Link to comment Share on other sites More sharing options...
Botus Posted April 26, 2021 Share Posted April 26, 2021 check with diagnostics the later one was a bit more clever and might tell you whats going on.... I had a bulb short (with dodgy broken filament) and it turned off all the brake lights !!! couldn't be bothered to let me know, but the diagnostics knew all about it Quote Link to comment Share on other sites More sharing options...
