Focus mk3 2011 duratec tdci. ABS FAULT
First Post.
ABS /TRACTION CONTROL  Fault .
Car went into limp mode.
RAC called fault cleared , he did say there isn't much info stored . Should not have activated limp mode .
I drove 17 miles without issue with RAC following me home .
Speed of up to 60 mph .
Fault returned activated limp mode again .
RAC cleared fault again.
But there was much more recorded than before.
He said ECU may be failing.
 Only got 100 yds before Limp Mode came back.
While still Free Wheeling .
I turned ignition off and on again .
Restarted engine faults cleared them selves.
I have driven 80 miles since without issue.
RAC Mechanic was going to e mail the  scanner report but has not done so.
On the steering wheel controls I  am able to go into ECU to check engine statious.
It says NO FAULTS .
I have a cheap OBD11 scanner which also says no codes recorded.
Looking to buy a better scanner any recommend.
Rgds. Ian
  Only 75 emoji are allowed.
  • Create New...
Forums
News
Membership
