aescilus Posted April 27, 2021 Share Posted April 27, 2021 Hi, I've got a 1.25 mk7 and it's started to make this rattling noise which after looking around in the bay I can only see that it may be a bearing or pulley that's connected to the same belt as the alternator. Would really like your opinions on this as afraid it may snap lol, there is also grease on the bearing that touches the belt Here is a video: https://streamable.com/26avom This is what I think it is: Thanks Ash Quote Link to comment Share on other sites More sharing options...
aescilus Posted April 29, 2021 Author Share Posted April 29, 2021 Anyone? Quote Link to comment Share on other sites More sharing options...
Aldridge Andy Posted April 30, 2021 Share Posted April 30, 2021 All you could really do if you suspect the auxiliary drive belt tensioner could have the start of bearing failure, is remove the belt and rotate / spin each of the connected components and listen for any noises. If it were me and as auxiliary drive belts aren’t that expensive I’d refit a new belt rather than reuse the existing. Quote Link to comment Share on other sites More sharing options...
